    TIG Mirror plugin crashes SU7
    17 Posts 5 Posters 3.7k Views 5 Watching
    • C
      CalypsoArt
      I use this plugin a lot. Since getting SU7 it crashes the program often. It still works with simple geometry, but as components and groups get added it fails. Never had crashes before SU7. The plugin usually gets to the final "erase original selection" then the bugsplat.
      Anyone else experiencing this?
      • TIGT
        First report.
        If you erase original does it crash?
        If you keep original does it crash?
        What things are you mirroring - raw geometry, groups, components ?
        • C
          CalypsoArt
          @tig said:
          First report.
          Tig,
          Thanks for the reply. I'll check the erase/no erase the next time it starts happening. But I'll say I almost never erase the original so I know it crashes then. It does not crash all the time, but when it begins to, then I cannot use the plugin with that particular drawing any longer. Even mirroring a simple box will then crash SU. I was wondering, could this have anything to do with video drivers? My system updated to Vista Service pack 2 and then I started having video problems. I rolled back the driver to an earlier one that worked but I still have odd effects at times.
          I'm using Vista (Sp2) and nVidia GeForce Go 7900gs
          • TIGT
            I wouldn't suspect the drivers. Try again ensuring that the Outliner is not open or at least rolled up - that bug is known to cause splats...
            • N
              NewOne
              It crashes for me a lot and I can't tell exactly when. First time I suspected that it crashes when I mirror a group who have inside a component, but is not that. If it crashes once, it will crash every time on that geometry, even I close and reopen the drawing. As I remember, bugspat happens only when I choose to keep the geometry (for this i use the plugin mostly), so now I delete original geometry, then I use UNDO (thanks TIG for not using start-commit opperation πŸ˜„ )
              • C
                CalypsoArt
                I was unaware of this. I have been keeping the outliner open lately. I'll see how that works.
                • N
                  NewOne
                  Is there a way to control the state of Outliner (and other windows) ? Because A lot of Sketchup functions are slowed down when Outliner is opened. I'm thinking if it's possible that a script that is influenced by Outliner's state, to be able to collapse it, or at least to close it. ❓
                  • C
                    cjthompson
                    Sketchup.send_action(21513) will shrink the outliner, although it will only work on Windows. I'm not sure if it will help or not.
                    • N
                      NewOne
                      Oh, it DOES help !! I will try it soon.
                      • TIGT
                        There is a script [Jim's ?] that will roll-up the Outliner on a PC. I've used it inside some recent susceptible scripts but Mirror is quite old so it doesn't have it. The bug is with Outliner not the scripts... I'll look at implementing something in an update of Mirror BUT in the meanwhile ensure that the Outliner window is not 'open' when running ANY script that makes or manipulates groups...
                        • kaluK
                          kalu
                          I have Sketchup 8 Latest version PRO and run windows 7 64bit. I install the Mirror 3.5 and when I make a simple group and mirror it crash my sketchup. Any help?... Do I have to Install the old version?
                          Thanks.
                          THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                          • TIGT
                            Thanks.
                            It fails if Sketchy Physics is installed - it seems that that script rewrites some core Group methods that Mirror needs and so it splats. Try temporarily removing SP and see if it works - if not we have another problem...
                            • kaluK
                              kalu
                              I uninstalled the SP and nothing happened so we still have the same problem. Maybe we need some more stable solution for Sketchup 8. I try Sketchup 7.1 and works fine, the latest version crashes...
                              My 2 cents.
                              Thanks for your hard work. I love mirror plugin.
                              • TIGT
                                My 2 cents.
                                Works fine in v8 for me without SP ???
                                What else do you have installed ? [PM if desired,,,]
                                • kaluK
                                  kalu
                                  Hi Tig:
                                  I have installed:
                                  Vray, extrusion tools, 1001bit tools, 2d tools, 3dxsketchup, bz_toolbar, Podium 2.0, Sculp tools, round edge, cd archland, cd drawtools, scf drawtools, scf powerbar, cd standard, cd select, shape bender, door tools, ferrary sketch, frontface (tm), projections, fur_tools, idx renditioner, NUL transformation, layer toold, layer manager, mirror 3.5, surface operations, profile builder, D.B. Tools, Skindigo, soap bubble, subdivide and smooth, twilight, vuexport, windows tools, curviloft, Fredoscale, tools on surface, Roundcorner, Booltools, shaderlight, Dynamic Components, Sandbox, Solar north.
                                  That's all..
                                  • TIGT
                                    I have now made v3.6 which might just avoid the glitches caused by other scripts clashing with API methods. It now copies groups quite differently... Download it from here http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                                    • kaluK
                                      kalu
                                      WOW Works perfect No problems at all, you are the meeeennnn!!!
                                      Thank you!!!
