    Ruby Script Video Tutorial - Multiple PushPull Script
    5 Posts 2 Posters 2.9k Views 2 Watching
    • Chris FullmerC Offline
      Hi, this video shows how to write a script the does a push/pull over many selected faces. Its about 10 lines of code, and I explain it in under 5 minutes. I could even be simplified down to 1 line of code really. But that is pretty dense code. So writing it in 10 lines is easier to read 😄
      [flash=1280,745:1hr2fbsm]http://www.youtube.com/v/W-pDilrOLfY&hd=1[/flash:1hr2fbsm]
      Hope its helpful,
      Chris
      All my Plugins I've written
      • E Offline
        Ecuadorian
        Thanks, Chris. 👍
        I'm sure you'll reach a wider audience via YouTube.
        -Miguel Lescano
          Yeah, that is my hope. I am thinking maybe if I put enough of these together, I'll get a nice little stream of videos put together.
          It took me many tried to figure out how to make the text be legible. I finally got it, but its a seriously wide video - sorry about that. If you're monitor is set to 1024x768, this won't fit!
          So thanks for checking it out!
          Chris
          • E Offline
            Ecuadorian
            I'm using a combination of CamStudio and Sizer to record a window of exactly 1280x720. What are you using for this, Chris?
            -Miguel Lescano
            • E Offline
              Ecuadorian
              Oh, and Chris, you can add &fs=1 to the video embed code to allow fullscreen playback. This solves the problem with smaller monitors. The resulting code woud be:
              [flash=1280,745]http://www.youtube.com/v/W-pDilrOLfY&hd=1&fs=1[/flash]
              -Miguel Lescano
