Ruby Script Video Tutorial - Multiple PushPull Script
Hi, this video shows how to write a script the does a push/pull over many selected faces. Its about 10 lines of code, and I explain it in under 5 minutes. I could even be simplified down to 1 line of code really. But that is pretty dense code. So writing it in 10 lines is easier to read
[flash=1280,745:1hr2fbsm]http://www.youtube.com/v/W-pDilrOLfY&hd=1[/flash:1hr2fbsm]
Hope its helpful,
Thanks, Chris.
I'm sure you'll reach a wider audience via YouTube. -
Yeah, that is my hope. I am thinking maybe if I put enough of these together, I'll get a nice little stream of videos put together.
It took me many tried to figure out how to make the text be legible. I finally got it, but its a seriously wide video - sorry about that. If you're monitor is set to 1024x768, this won't fit!
So thanks for checking it out!
Oh, and Chris, you can add &fs=1 to the video embed code to allow fullscreen playback. This solves the problem with smaller monitors. The resulting code woud be:
[flash=1280,745]http://www.youtube.com/v/W-pDilrOLfY&hd=1&fs=1[/flash]
