    How to use Ruby API
    28 Posts 5 Posters 3.0k Views 5 Watching
    • TIGT
      Edges, Loops, Curves, Faces, etc have vertices and those vertices have a position vertices.position (i.e. a point)
      points have x/y/z values vertices.position.x
      DON'T muddle them up! ❗
      • honoluludesktopH
        honoluludesktop
        OK, so how do I get the coordinate values for each vertex on each face.vertices? I think I understand vertex.position, and face.vertices, but how do I get a collection of vertex for each vertices.
        Can't be impossible, can it?
        • Chris FullmerC
          look at the Face.vertices here:
          Error 404 (Not Found)!!1
          (code.google.com)
          it says what it returns - an array of vertx objects. So to get positions for all those vertices, you need to loop through that array. Something like this:
          ` vert_array = my_face.vertices
          position_array = []
          x_position_array = []
          vert_array.each do |v|
          position_array << v.position
          x_position_array << v.position.x
          end`
          All my Plugins I've written
          • TIGT
            That is not logical ❗
            If you have run vertices=face.vertices you already have a collection [i.e. an array] of the face's vertices !
            If you then look at each of them you can get their positions as another array,
            e.g. positions=[]; vertices.each{|v|positions<< v.position}
            Now you can look at each 'position' in that array (i.e. it's a point) and get the x/y/z values etc
            positions.each{|p|puts p.x;puts p.y;puts p.z}
            You seem to making this more complicated than it needs to be...
            • honoluludesktopH
              honoluludesktop
              AGH!!!, Thats what happens when you don't really know what you are doing. I think I got it, again:-) puts(face_pts.position.to_a) almost at the bottom. Basically, I took a "vertices", got tne number of points by "vertices.length", then extracted each "vertex" by "This_number=vertices[0 to (length-1)]". The following runs in Web Console.
              model = Sketchup.active_model
              entities = model.entities
              selection = model.selection
              if model.selection.empty?
              	entities = model.active_entities
              else
              	entities = model.selection
              def open_comp_inst_file(comp_inst_name,model)
              	comp_inst_file_name=File.basename(model.path)
              	path=File.dirname(model.path)+"\\"
              	out_name=comp_inst_name+".txt"
              	out_path=path+out_name
              	$dxf_ci_file=File.open(out_path,"w")
              entities.each do |e|
              	if e.is_a? Sketchup;;ComponentInstance
              		puts("Component")
              		comp_inst_name=e.definition.name
              		comp_inst_collection=e.definition.entities
              		#open text file for output
              		#open_comp_inst_file(comp_inst_name,model)
              		comp_inst_collection.each do |e|
              			comp_inst_faces_collection=[]
              			if e.is_a? Sketchup;;Face
              				#make collection of faces
              				comp_inst_faces_collection.push e
              				vertices_collection=[]
              				comp_inst_faces_collection.each do |e|
              						if e.vertices
              							#vertice collection
              							vertices_collection.push e.vertices
              							vertices_collection.each do |e|
              								no_vert=e.length
              								cnt_vert=no_vert
              								puts("Vertices")
              								no_vert.times do
              									face_pts=(e[no_vert-cnt_vert])
              									cnt_vert=cnt_vert-1
              									puts("Vertex")
              				end #loop
              			end #if
              		end #loop
              		#close text file
              		#$dxf_ci_file.close
              Here is some sample output:
              %(#408000)[Start Component
              Starts Vertices
              Start Vertex
              69.6952995222671
              5.52489094225734
              0.0
              Start Vertex
              26.421563780178
              0.0
              0.0
              Start Vertex
              0.0
              34.7137089981752
              0.0
              Start Vertex
              16.8521719619112
              74.9523089386077
              0.0
              Looks OK?
              • J
                Jim
                Well, what are you doing? Try to make a precise statement of the purpose of the routine. In
                English first, then Ruby.
                This prints a summary of faces and vertices in the Definitions.
                    else
                    instance_count = 0
                            instance_count += 1
                            puts("Component; #{instance_count} #{e.definition.name}")
                            face_count = 0
                            e.definition.entities.each do |e|
                                    face_count += 1
                                    puts "  face; #{face_count}"
                                    vertex_count = 0
                                    e.vertices.each do |v|
                                        vertex_count += 1
                                        puts "    vertex #{vertex_count} id;#{v.object_id}  pos;#{v.position}"
                Note since some faces share vertices, and all vertices are listed, some vertives will be duplicated.
                Component; 2 Component#2
                  face; 1
                    vertex 1 id;48589944  pos;(2.160711", 1.853015", 0")
                    vertex 2 id;48589932  pos;(0", 1.853015", 0")
                    vertex 3 id;48589920  pos;(0", 1.853015", 2.160338")
                    vertex 4 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                  face; 2
                    vertex 2 id;48589692  pos;(2.160711", 0", 0")
                    vertex 3 id;48589680  pos;(0", 0", 0")
                    vertex 4 id;48589932  pos;(0", 1.853015", 0")
                  face; 3
                    vertex 1 id;48589680  pos;(0", 0", 0")
                    vertex 3 id;48589464  pos;(2.160711", 0", 2.160338")
                    vertex 4 id;48589452  pos;(0", 0", 2.160338")
                  face; 4
                    vertex 1 id;48589932  pos;(0", 1.853015", 0")
                    vertex 2 id;48589680  pos;(0", 0", 0")
                    vertex 3 id;48589452  pos;(0", 0", 2.160338")
                    vertex 4 id;48589920  pos;(0", 1.853015", 2.160338")
                  face; 5
                    vertex 1 id;48589464  pos;(2.160711", 0", 2.160338")
                    vertex 2 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                  face; 6
                    vertex 1 id;48589692  pos;(2.160711", 0", 0")
                    vertex 2 id;48589944  pos;(2.160711", 1.853015", 0")
                    vertex 3 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                    vertex 4 id;48589464  pos;(2.160711", 0", 2.160338")
                • honoluludesktopH
                  honoluludesktop
                  WOW! very compact, and fast, I will take a hard look at your code, and learn from it. Lets see how far I can get before having to post for help 🙂
                  Addenda: Well, I did have redundant code, and really need to learn how to format output. Would have never figured out Puts "#{e.position.x.to_f}" by myself.
                  • honoluludesktopH
                    honoluludesktop
                    Darn, I finished coding only to discover the "putdxf" I use for my CAD import has a bug that fails to locate multiple blocks correctly. I confirmed this by being unable to "putdxf" with the system's "getdxf". Will have to rewrite as a "command line" script. Thanks for everything, sorry I couldn't understand much of what you tried to explain to me. But, because of your help, I will get better in time 🙂
                    • 2 / 2
