⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Trace() - display message with traceback to caller
3 Posts 2 Posters 3.8k Views 2 Watching
    Al Hart
    I use this routine trace() to display debug messages from ruby files.
    trace_sample.rb
    For instance, including:
    trace("Entities in model; %s", Sketchup.active_model.entities.length)
    in a ruby function, will display something like:
    Entities in model; 1
        ^^^trace_sample.rb;24;in `test_trace'
    Showing the ruby file name and line number where you placed the trace.
    trace(format, values) can be used like puts or printf(), but you do not need to add a \n to get the carriage return. (This saves me millions of keystrokes a month - not typing in \n 😉 )
    Try the attached file. When you type in: load "trace_sample.rb" you should see a message like:
    In actual use, I usually define trace() within each class or module, so that I am not creating a global function. (Which might interfere with, be be overridden by, global functions from other developers.
    e.g.
    class RPS_class
        def trace(*args)
           ... (rest of code)
        end#def
    end#class
    Here is the source for trace if you want to grab it and use it:
    (Or else get it from the attachment - which also includes a sample use of trace())
    def trace(*args)
    	scall = caller(1)[0].to_s # who called the routine
    	scall2 = File;;basename(scall) # only the file name itself - no path
    	begin
    		smess = sprintf(*args)
    		puts smess + "\n    ^^^" + scall2
    	rescue
    		warn "arg ERROR in trace called from; " + caller(1)[0].to_s
    end#def
    Al Hart
    IRender nXt from Render Plus
      👍 Good stuff.
      Though, I have a thought:
      Why not define the trace method in a Trace class, and then include the class to the methods you want. That way you don't have multiple copies all over the place?
        Al Hart
        @thomthom said:
        :thumb: Good stuff.
        Good idea, I could include it in a module of functions.
        But I would still have to distribute the trace module with each application.
        And there might be a problem with versions. When a user had installed more than one RPS application, say a new version of A and and old version of B, then A might wind up inheriting from the B version of the module, if the B version was loaded into SketchUp after the A version.
        At one point we considered having a common set - called RPS_common. But still the problems of installing and uninstalling became difficult.
        Al Hart
