    Trace() - display message with traceback to caller
    3 Posts 2 Posters 4.1k Views 2 Watching
    • Al HartA
      Al Hart
      I use this routine trace() to display debug messages from ruby files.
      trace_sample.rb
      For instance, including:
      trace("Entities in model; %s", Sketchup.active_model.entities.length)
      in a ruby function, will display something like:
      Entities in model; 1
          ^^^trace_sample.rb;24;in `test_trace'
      Showing the ruby file name and line number where you placed the trace.
      trace(format, values) can be used like puts or printf(), but you do not need to add a \n to get the carriage return. (This saves me millions of keystrokes a month - not typing in \n 😉 )
      Try the attached file. When you type in: load "trace_sample.rb" you should see a message like:
      In actual use, I usually define trace() within each class or module, so that I am not creating a global function. (Which might interfere with, be be overridden by, global functions from other developers.
      e.g.
      class RPS_class
          def trace(*args)
             ... (rest of code)
          end#def
      end#class
      Here is the source for trace if you want to grab it and use it:
      (Or else get it from the attachment - which also includes a sample use of trace())
      def trace(*args)
      	scall = caller(1)[0].to_s # who called the routine
      	scall2 = File;;basename(scall) # only the file name itself - no path
      	begin
      		smess = sprintf(*args)
      		puts smess + "\n    ^^^" + scall2
      	rescue
      		warn "arg ERROR in trace called from; " + caller(1)[0].to_s
      end#def
      Al Hart
      IRender nXt from Render Plus
        👍 Good stuff.
        Though, I have a thought:
        Why not define the trace method in a Trace class, and then include the class to the methods you want. That way you don't have multiple copies all over the place?
        • Al HartA
          Al Hart
          @thomthom said:
          :thumb: Good stuff.
          Good idea, I could include it in a module of functions.
          But I would still have to distribute the trace module with each application.
          And there might be a problem with versions. When a user had installed more than one RPS application, say a new version of A and and old version of B, then A might wind up inheriting from the B version of the module, if the B version was loaded into SketchUp after the A version.
          At one point we considered having a common set - called RPS_common. But still the problems of installing and uninstalling became difficult.
          Al Hart
