    Making components...
    3 Posts 3 Posters 317 Views 3 Watching
      tpoz
      Hello y'all,
      I'm having quite a hard time trying to figure out how to make components 😞
      I can retrieve components from the Component Samples folder and that seems to work, but what I really want to do is ask the user what the dimensions are (of a generic house or an image of a tree) and make the 'house' those dimensions.
      I think my problem is that I don't know how to define the edges/faces as a component. I don't really know what to replace
      componentdefinition= definition.load path
      with, or how to define my 'house' in the DefinitionList, or if this even makes sense.
      Any help would be greatly appreciated πŸ˜„
      Thanks,
      laura
        house = model.definitions.add("MyHouse")
        house.entities.add_face(...)
        model.active_entities.add_instance(house)
          Alternatively just make a group and add entities to it... then turn it into a component when you are done...
          ### you'll need to define stuff like entities, pt1/2 etc earlier on - it's skipped here for brevity
          group=entities.add_group()
          group.entities.add_line(pt1,pt2)
          ### add as much as you want...
          instance=group.to_component
          definition=instance.definition
          definition.name="My Definition's Name"
          instance.name="My Instance's Name"
          tr=Geom;;Transformation.new(ptxyz) ### ptxyz = new insertion point, as it'll be located at the ORIGIN by default
          instance.transform!(tr) ###to move or even rotate/scale it as needed
          ### etc
          ### to now add further stuff to definition use### definition.entities.add_...
