    Plugin Menu "Selection"
    12 Posts 4 Posters 665 Views 4 Watching
    • kenK Offline
      ken
      I have in the plugin memu, the item "Selection". This menu item has the right side arrow head indicating it has a sub menu. However, when I click or hover on Selection nothing happens.
      Is anyone else having problem with this menu item? Also to what script does this menu item belong?
      Thanks in advance
      PC, Vista, latest version of Sketchup.
      Ken
      • mitcorbM Offline
        mitcorb
        Yes, I have the same issue on at least one of the machines I use. I primarily use Sketchup 6 at home and Sketchup 6 pro at work. I have not used this menu item for some time, but try this, if you haven't already. Select something first and then invoke the Selection command you are talking about and see if the flyout menu items appear. I think this is part of a plugin by thomthom, but not sure. I will check this out, get back.
        mitcorb
        • mitcorbM Offline
          mitcorb
          Ken:
          I tried a few things with simple geometry.
          After selecting and right clicking for context menu, Selection shows up and the arrow flies out. I get "Extend edges".
          I just happened to have a couple of stray lines one headed in the x direction and one headed in the y direction and both capable of intersecting, that is in this case one was on a collision course with the other if it was extended. It worked like Extend in Autocad. Select the line you want to extend to and then call the command with a right click selection and flyout then select the line you want to extend. In my case this worked under this condition. I did not do a whole lot of additional testing.
          Apparently, the Plugin menu instance of the command is non functional, and the context menu instance is the one that works.
          mitcorb
          • mitcorbM Offline
            mitcorb
            Ken:
            Is the next item in the Plugins menu after Selection, Extend Edges? If so, that means that the flyout feature is dead and the command is in the menu. Some glitch in the ruby, maybe.
            • kenK Offline
              ken
              @mitcorb said:
              Ken:
              Well, you are right. The next menu item is "Extend Edges".
              Could some one please tell me which script the item, "Selection" is associated with. I know ending the sentence in a preposition.
              It would be nice if a script had in it's name, a reference to the menu item, e.g. "Script Name-Selection-Author initials". I know the script's name would be long, however it would make it easier to try and figure out what is going on.
              Thanks for your help. Now, if I just knew what to do next. Heck, now if I even could figure out what "Selection" was intended to do. I was trying to find a script that would erase construction lines. I know I have it somewhere.
              Ken
              • mitcorbM Offline
                mitcorb
                See Edit>Delete Guides native SU command to delete the dotted lines created for example with Tape Measure.
                • kenK Offline
                  ken
                  Thanks for the info, however, I only wanted to delete the construction lines, not the construction points.
                  Again thanks
                  Ken
                    Again thanks
                    Ken
                    There are a couple of scripts I did to delete cpoints and clines separately - see http://www.sketchucation.com/extensions-index/ Author TIG names start with 'DeleteCon...' Available on Didier Bur's site http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
                    • kenK Offline
                      ken
                      Tig
                      I went looking and found your erase Clines. It worked like a champ.
                      I though there was a script that allowed me to select, Cline, Cpoints, an etc. I can't seem to find that script now.
                      Thanks for all your scripts.
                      Ken
                        You can use my Selection Toys plugin to filter out different types of entities from the selection. But it will not search and find all in model.
                          Tig
                          Ken
                          It's easy enough - this code snippet can be copy/pasted into a text file in Plugins named something like selectCgeom.rb
                          ### TIG 2009 (c)
                          ### various construction (guide) geometry selection methods...
                          def selectactiveclines()
                            model=Sketchup.active_model
                            ents=model.active_entities
                            cgeom=[]
                            ents.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionLine}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectmodelclines()
                            ents=model.entities
                            cgeom=[]
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectallclines()
                            ents=model.entities
                            cgeom=[]
                            defs=model.definitions
                            defs.each{|d|d.entities.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionLine}}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectactivecpoints()
                            cgeom=[]
                            ents.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionPoint}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectmodelcpoints()
                            ents=model.entities
                            cgeom=[]
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectallcpoints()
                            ents=model.entities
                            cgeom=[]
                            defs.each{|d|d.entities.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionPoint}}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectactivecgeom()
                            cgeom=[]
                            ents.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionPoint or e.class==Sketchup;;ConstructionLine}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectmodelcgeom()
                            ents=model.entities
                            cgeom=[]
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          def selectallcgeom()
                            ents=model.entities
                            cgeom=[]
                            defs.each{|d|d.entities.each{|e|cgeom<<e if e.class==Sketchup;;ConstructionPoint or e.class==Sketchup;;ConstructionLine}}
                            ss=model.selection
                            ss.clear
                            ss.add(cgeom)
                          end#def
                          ### It works for all active, all in model (including inactive) and 'all' including those within definitions
                          ### It works for clines or cpoints or both
                          ### E.G. in the console type selectactiveclines to make your selections etc
                          ### I'll leave the menus up to you...
                          • kenK Offline
                            ken
                            Tig
                            Thanks for the info and the help. However, I found the script I was looking for, ConsDeleteContext.rb, which is one of your scripts. I just forgot that it is a context selected script.
                            So now I am working again. Maybe I will make a small database with all the scripts that I have or can find, and enter just what they do, who made the script and how to activate the script. As soon as I get the time.
                            Tig, again thanks for your scripts.
                            Ken
