    Downloading plugins
    6 Posts 5 Posters 780 Views 5 Watching
    • N
      nuclearmoose
      Does a person really have to visit each and every post to look for a download link for each plugin? I notice that the plugin index doesn't have all of the plugins that I have seen mentioned in the forums.
      I'm sorry if I'm missing something obvious, but if I want to access and use Chris Fuller's scripts, for example, it looks like it could take quite a long time to locate and then download his plugins.
      I'd appreciate any advice you can give.
      Thanks.
      Craig.
      • E
        Ecuadorian
        Most plugins are known by more than one name, that's why they're not easy to find in the index.
        For Chris' plugins, just follow the link under his signature.
        -Miguel Lescano
        • mitcorbM
          mitcorb
          One good thing is that most of the available plugins are to be found in the Ruby Discussions subforum and the thread title starts with the word [Plugin]. So you should be able to use the Search box to see a plethora of available ones from all authors.
          • D
            d12dozr
            Have you seen the Visual Index Thread?
            http://goo.gl/f7ooYh
            • J
              Jim
              I've tried to bookmark them in this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
              • N
                nuclearmoose
                Thank you, all, for your links and suggestions! Much appreciated. I like the visual guide, especially.
                I have to say I'm very thankful and impressed at the patience demonstrated by all of your responses. Cheers to you all.
                C.
