    Downloading plugins
    6 Posts 5 Posters 721 Views 5 Watching
    • N Offline
      nuclearmoose
      Does a person really have to visit each and every post to look for a download link for each plugin? I notice that the plugin index doesn't have all of the plugins that I have seen mentioned in the forums.
      I'm sorry if I'm missing something obvious, but if I want to access and use Chris Fuller's scripts, for example, it looks like it could take quite a long time to locate and then download his plugins.
      I'd appreciate any advice you can give.
      Thanks.
      Craig.
      • E Offline
        Ecuadorian
        Most plugins are known by more than one name, that's why they're not easy to find in the index.
        For Chris' plugins, just follow the link under his signature.
        -Miguel Lescano
        • mitcorbM Offline
          mitcorb
          One good thing is that most of the available plugins are to be found in the Ruby Discussions subforum and the thread title starts with the word [Plugin]. So you should be able to use the Search box to see a plethora of available ones from all authors.
            d12dozr
            Have you seen the Visual Index Thread?
            http://goo.gl/f7ooYh
              Jim
              I've tried to bookmark them in this post: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
              • N Offline
                nuclearmoose
                Thank you, all, for your links and suggestions! Much appreciated. I like the visual guide, especially.
                I have to say I'm very thankful and impressed at the patience demonstrated by all of your responses. Cheers to you all.
                C.
