    Bedroom
    24 Posts 9 Posters 2.5k Views 9 Watching
    • N
      NewOne
      A project that had no final, so I decided to show it to you πŸ˜„
      • tridemT
        tridem
        Hi Newone!
        cannot comment, it's almost perfect work.
        if I must... it shouldn't be the sky behind the door (or really the room exit to the external?) and I noticed (4th picture) in the mirror the reflection of the sky has no the light flare as watching to the window, it looks strange.. but that wooden texture is amazing.. i like that picture very much πŸ‘
        Bye
        Luca
        • N
          NewOne
          Yes... It's a little strange... especially the door. I didn't imagine it will look like that. About the mirror I can't explain myself why. It might be a physically correct phenomenon, because the the mirror reflected a portion of the sky which was a little far from Sun... and a normal mirror doesn't have such a high level of reflection, i think.
          • tridemT
            tridem
            I don't believe is because of physically correct phenomenon, although is a darker portion of sky you can see in 1st picture that looking about in that direction through the window there are always a lot of shine. maybe matter of rendering method and settings ... what render engine are you using?
            • N
              NewOne
              That was rendered with Maxwell Render 1.7.1
              • tridemT
                tridem
                just for curiosity, you could try set the specularity of the mirror higer and see what happens.
                bye
                • olisheaO
                  olishea
                  wow πŸ‘
                  very nice, especially scene 4
                  oli
                  • boofredlayB
                    boofredlay
                    Very nice.
                    • dermotcollD
                      dermotcoll
                      Very nice - just wondering from a woodworking point of view why the drawer front on the bedside locker seems to project above the top surface?
                      I dont like to nit pick as I can only dream of this quality of model / render.
                      When you burn your arse - you gotta sit on the blisters!!
                      • J
                        JHuman
                        Looks good! I especially like the fourth image, great job!
                        • Doweth!
                        • X
                          xrok1
                          very nice! would love to get my hands on that TV model is it from the warehouse? and i really love the painting too 😲
                          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                          • N
                            NewOne
                            Well, if I understand correctly, this is what you say (see image). And the answer is simple: To not use handlers πŸ˜„ You can grab each drawer from the edge that goes over the box bounds.
                            • dermotcollD
                              dermotcoll
                              Cheers Newone
                              knew you would have a good reason for it! I use a back mitre cut when I want to get rid of handles. It gives a flush finish on the top of the bedside cabinet but still easy to open. The image is not to scale -just to explain the concept.
                              • TIGT
                                You've been in my bedroom ! πŸ˜‰
                                • D
                                  dedmin
                                  http://www.blum.com/us/en/01/40/90/index.php
                                  • N
                                    NewOne
                                    to dermotcoll and dedmin: I use that oblique cutting, also I use edge handles, and also I use BLUM a lot πŸ˜„ I would be glad to discuss more about furniture; is it here a subforum for such discussions?
                                    • X
                                      xrok1
                                      i say its your thread discuss what you like! i don't think you can hijack yourself although some people come close! πŸ˜†
                                      • dermotcollD
                                        dermotcoll
                                        I only recently discovered the servo option on drawers as well (electrically motorised arm). I have never used this Tip -on product but cheers for the heads up
                                        Sorry if I've hijacked it - newone sign on for the woodworking forum in the user control area and you can meet plenty of woodies there!!
                                        • D
                                          dedmin
                                          Blum's documentation is very helpful and detailed. However, it is not very easy to implement all this in SketchUP by hand. So, there comes BlumDynalog - a software to build cabinets with Blum's hardware - it gives cutlist, BOM, drawings and connections with AutoCAD. From AutoCAD to .dwg and then import in SketchUP - here we go
                                          • dermotcollD
                                            dermotcoll
                                            Dedmin
                                            I have dynalog and use it for positioning runners and hinges on bespoke cabinets with internal drawers etc. Never knew you could export to autocad - thanks for the heads up. Dont think I will ever need to model to that level of detail on the inside of a cabinet however!!!
                                            • 1 / 2
