    Bedroom
    24 Posts 9 Posters 1.3k Views 9 Watching
    • N Offline
      NewOne
      A project that had no final, so I decided to show it to you πŸ˜„
      • tridemT Offline
        tridem
        Hi Newone!
        cannot comment, it's almost perfect work.
        if I must... it shouldn't be the sky behind the door (or really the room exit to the external?) and I noticed (4th picture) in the mirror the reflection of the sky has no the light flare as watching to the window, it looks strange.. but that wooden texture is amazing.. i like that picture very much πŸ‘
        Bye
        Luca
        • N Offline
          NewOne
          Yes... It's a little strange... especially the door. I didn't imagine it will look like that. About the mirror I can't explain myself why. It might be a physically correct phenomenon, because the the mirror reflected a portion of the sky which was a little far from Sun... and a normal mirror doesn't have such a high level of reflection, i think.
          • tridemT Offline
            tridem
            I don't believe is because of physically correct phenomenon, although is a darker portion of sky you can see in 1st picture that looking about in that direction through the window there are always a lot of shine. maybe matter of rendering method and settings ... what render engine are you using?
            • N Offline
              NewOne
              That was rendered with Maxwell Render 1.7.1
              • tridemT Offline
                tridem
                just for curiosity, you could try set the specularity of the mirror higer and see what happens.
                bye
                • olisheaO Offline
                  olishea
                  wow πŸ‘
                  very nice, especially scene 4
                  oli
                  • boofredlayB Offline
                    boofredlay
                    Very nice.
                    • dermotcollD Offline
                      dermotcoll
                      Very nice - just wondering from a woodworking point of view why the drawer front on the bedside locker seems to project above the top surface?
                      I dont like to nit pick as I can only dream of this quality of model / render.
                      When you burn your arse - you gotta sit on the blisters!!
                        JHuman
                        Looks good! I especially like the fourth image, great job!
                        • Doweth!
                        • X Offline
                          xrok1
                          very nice! would love to get my hands on that TV model is it from the warehouse? and i really love the painting too 😲
                          • N Offline
                            NewOne
                            Well, if I understand correctly, this is what you say (see image). And the answer is simple: To not use handlers πŸ˜„ You can grab each drawer from the edge that goes over the box bounds.
                              dermotcoll
                              Cheers Newone
                              knew you would have a good reason for it! I use a back mitre cut when I want to get rid of handles. It gives a flush finish on the top of the bedside cabinet but still easy to open. The image is not to scale -just to explain the concept.
                              • TIGT Online
                                You've been in my bedroom ! πŸ˜‰
                                  dedmin
                                  301 Moved Permanently
                                  (www.blum.com)
                                  • N Offline
                                    NewOne
                                    to dermotcoll and dedmin: I use that oblique cutting, also I use edge handles, and also I use BLUM a lot πŸ˜„ I would be glad to discuss more about furniture; is it here a subforum for such discussions?
                                    • X Offline
                                      xrok1
                                      i say its your thread discuss what you like! i don't think you can hijack yourself although some people come close! πŸ˜†
                                        dermotcoll
                                        (www.blum.com)
                                        I only recently discovered the servo option on drawers as well (electrically motorised arm). I have never used this Tip -on product but cheers for the heads up
                                        Sorry if I've hijacked it - newone sign on for the woodworking forum in the user control area and you can meet plenty of woodies there!!
                                          dedmin
                                          Blum's documentation is very helpful and detailed. However, it is not very easy to implement all this in SketchUP by hand. So, there comes BlumDynalog - a software to build cabinets with Blum's hardware - it gives cutlist, BOM, drawings and connections with AutoCAD. From AutoCAD to .dwg and then import in SketchUP - here we go
                                            dermotcoll
                                            Dedmin
                                            I have dynalog and use it for positioning runners and hinges on bespoke cabinets with internal drawers etc. Never knew you could export to autocad - thanks for the heads up. Dont think I will ever need to model to that level of detail on the inside of a cabinet however!!!
