    Copy Array Along Path tool...have a look.
    46 Posts 15 Posters 123.7k Views 15 Watching
    • C
      Click Draw
      Hi there,
      I know I've been posting a lot of questions lately, so seeing as I'm on a roll, here is another. Have a look at the attached and see if you can help. Also, once I can get the proper outcome and know how, I'd like to experiment with changing or replacing the component with another. I think this will come in very useful for creating rope, chain, spine type shapes, etc....A good example would be "Doc Oc" arms in Spiderman. Hope you all know what I mean.
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • TIGT
        This along awaited update of RickW's tool CopyAlongPath - to rotate as it copies... I'm do some other stuff that will involve an algorithm that could be applied to this - but don't hold your breath...
        • C
          Click Draw
          Do you know of a user guide or PDF on the proper settings...if there is a settings guideline.? I would use it more if I knew how to set it up properly.
          Jeff
          • E
            Ecuadorian
            Takeshi Hashimoto wrote a basic, but good explanation:
            http://www.pushpullbar.com/forums/ruby-scripts/9467-visual-index-ruby-scripts-3.html#post132098
            I'm also waiting for a version that can do what you want...
            -Miguel Lescano
            • C
              Click Draw
              Thanks Miguel,
              Seems to work fine when the path is 2D by not when 3D. So far I have made a work around using the Radial Bending ruby....just more time consuming.
              Cheers,
              Jeff
              • E
                Ecuadorian
                Jeff, I made a request very similar to yours back in March. You might want to check the thread for some ideas people gave:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=17285
                EDIT: Now that I think about it, perhaps a combination of 1001bit's extrude along sloping path + Chris Fullmer's Components to Faces could be the ticket.
                -Miguel Lescano
                • Chris FullmerC
                  My perpendicular face tools will do it. It just doesn't do it as an array. You have to click where you want each face to be applied. So it could be useful, but also tedious if you need a perfectly spaced array.
                  Chris
                  All my Plugins I've written
                  • C
                    Click Draw
                    Hi Chris,
                    Ya...I used it in the sample above but I would for sure be very time consuming. I was wondering, each face is created as a group, could it be possible to have it place a component on a node instead of a circle, square or custom face. Kind of a combo between copy path and perp faces.... what do you think?
                    Thanks,
                    Jeff
                    • R
                      RickW
                      2D rotation works for components, but 3D rotation has yet to be implemented.
                      RickW
                      www.smustard.com
                      • E
                        Ecuadorian
                        This will make a nice commercial script, Rick. 😎
                        -Miguel Lescano
                        • JClementsJ
                          JClements
                          Jeff, I use perpendicular to path as well to do what you showed in your first posting, but it can be a tedious process.
                          If it could be automated AND combined with scale along a path from one object to a rescaled-copy of itself, it would sure be helpful in producing things such as reduced elbows.
                          Lets hope ...
                          • simon le bonS
                            simon le bon
                            "This along awaited update of RickW's tool CopyAlongPath" Yes indeed dear Rick, we agree with TIG. We need it! (we want it 😉 )
                            this is my try:
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray001th.jpg
                            3d_grid.rb
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray002th.jpg
                            Weld v.3.000 by Rick Wilson
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray003th.jpg
                            BezierSpline v1.21 by fredo
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray004th.jpg
                            Perpendicular Face Tools by Chris Fullmer
                            Lets hope ...
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray005th.jpg
                            2 Faces + Path ver. 1.4. by Kirill
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray006th.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray007th.jpg
                            Components onto Faces v1.0 by Chris Fullmer
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray008th.jpg
                            As Jean lemire always say: "just ideas" 😄
                            simon.
                            • simon le bonS
                              simon le bon
                              Tweaking the process:
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray009th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray010th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray011th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray012th.jpg
                              *s
                              • X
                                xrok1
                                love that chain! i'd like to see it rendered with a glass material. 😉
                                “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                • simon le bonS
                                  simon le bon
                                  Hi Rocky
                                  Please take it and make it at your convenience 😉
                                  (click the pic for Skp)
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray013th.jpg
                                  ../sim
                                  • simon le bonS
                                    simon le bon
                                    Playing with the process..
                                    (easy and fast)
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray014th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray015th-1.jpg
                                    (two components made with the same 60° rotated)
                                    *s
                                    • Bob JamesB
                                      Bob James
                                      @simon le bon said:
                                      (easy and fast)
                                      Is your "easy and fast" the same eight-step process in your previous post or have you come up with a real "easy and fast"?
                                      • P
                                        pav_3j
                                        simon you are a master of getting the best results using methods most don't think of!
                                        i'm still a little confused by the process, but i'll get there!
                                        pav
                                        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                        • P
                                          pav_3j
                                          ah i get it now simon, thank you very much for the written explaination.
                                          i think one thing you may have missed out (as i understand it) is that the amount of steps you have to take with the 2 faces and a path tool, must equal the amount you have segmented the curve by, or the faces will not end up on the end point of each line.
                                          correct?
                                          thank you again.
                                          pav
                                          • C
                                            Click Draw
                                            Very clever Simon....I'll be trying this for sure!
                                            Thanks,
                                            Jeff
                                            PS: I wonder if it would be possible to have a ruby called "Replace segment with Component"...nah....I doubt that could be written 😉
                                            • 1 / 3
