    Drawing a Chair
    9 Posts 6 Posters 1.3k Views 6 Watching
      agrazdi
      I would thank anybody if i could get some advice or basic steps of how to draw this chair, it is the only picture of the chair that i have. I ve tried Photomatch but i didnΒ΄t get a good model.
      agrazdi
        Maybe this
        πŸ˜‰
        Your photo must be 3/4 view for use photomatch! πŸ€“
        Video 😎
          dyppmo
          Quick and dirty...
          1 - Draw a box the same size as the chair you want to make.
          2 - apply the photo to the front of the box.
          3 - use the line tool to draw the shapes.
          4 - use push pull as needed
          clean it up as needed using the tape tool to measure things and adjust them to uniform size
          • boofredlayB Offline
            boofredlay
            Well I had some time tonight agrazdi so I had a go at a tutorial for you.
            First let me say the best way to learn how to draw a chair is to measure one physically. If you can find a chair made similarly to this one that would be best. Note how it is put together. As well you should model each part of the chair as if you were going to build it for real. At least that is how I approach modeling in SketchUp.
            Ok, so here is the final result as well as a the SketchUp file tutorial. It is not perfect but I think it illustrates the point well. Just follow the scene tabs. If you have trouble with any of the steps just ask and I hope I can answer. That or someone else might chime in if I am unavailable.
            Hope it helps.
            Cheers.
            P.S. I just noticed I did not flare the top rail out. I figure I would point it out before Pilou does πŸ˜’ πŸ˜‰
            Chair2.skp
            • david_hD Offline
              david_h
              I played with this for a sec. Chris' Shape bender and Fredo's Freescale tool will help as well. Draw it straight on as usual and then bend and taper with the plugins. Should go just fine.
              Bonne Chance, mon ami.
              D
                dylan
                Nice tutorial Eric πŸ‘
                http://dmdarchitecture.co.uk/
                  agrazdi
                  Boofredlay
                  Awesome
                  Thanks a lot
                  agrazdi
                  • david_hD Offline
                    david_h
                    Or you can just do it like those guys said. . . . 😳 πŸ˜’
                      boofredlay
                      Thanks Dylan and your welcome agrazdi, I hope it helped.
