    Repeated Holes
    11 Posts 6 Posters 1.3k Views 6 Watching
    • O Offline
      Otis
      OK, so I have this cabinet side drawn that I need to place two rows of holes 6mm dia and 10mm deep in a 19mm thick side. I have the rows laid out and can make one hole just fine. Doing a hundred or so will be a PITA. There must be a way to do this quickly and efficiently . Any ideas ?
      Otis
        Hi Otis,
        Make a component of the hole with a feature to cut hole in the surface and use a linear array to evenly sort it along that row.
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=114526
        and
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=94867
        • E Offline
          Ecuadorian
          Make cylinders and substract them with BoolTools.
          EDIT: Csaba's idea seems better.
          -Miguel Lescano
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            See this SU file for ideas.
            Array of blind holes in plank.skp
            • E Offline
              Ecuadorian
              I learned a couple of tricks in that single SU file. Pure genius. Thanks, Jean. 👍
              Yet another way:
              1. Draw your plank and make a colored circle.
              2. Array it in one direction.
              3. Right click on any circle, go to select > all with same material to select all circles and array them in the other direction.
              4. Again pick any circle to select all with same material and use the first button in the Joint Push Pull toolbar to push pull them all at once by any length you type in.
              Optional step:
              5. If you need your holes to have the same material as the plank, just right click on any of them to select all with same material and apply the material of the plank.
              -Miguel Lescano
                From Jean Lemire
                Empty all circles in one shot by:
                1 - Select all.
                2 - SHIFT double click on the surface outside the holes to deselect it with all of its perimeter
                including the rectangular boundary and the circumfrence of all circles. This keeps only the inside of the circles selected.
                3 - Delete the selection
                don't works for me 😮
                I must make this 😉
                1 - Select all.
                2 - SHIFT + CTRL double click on the surface outside the holes to deselect it with all of its perimeter
                  Jean Lemire
                  Hi Pilou, hi folks.
                  I don't know why it doesn't work since the SHIFT key act as a toggle for the Select Tool. When pressed, you will see a small +/- sign beside the cursor meaning that anything clicked will be selected if it is not already selected or deselected if it is already selected.
                  Remember that you must press AND hold down the SHIFT key during this process.
                  Just ideas.
                    It'a a curious thing 😄 😒
                    Works in my case with only Shift but if you click twice separatly and not with a double click 😉
                    so 2 different selections one after one
                      Jean Lemire
                      Hi Pilou, hi folks.
                      Maybe the speed of your double click has been altered.
                      Just ideas.
                      • O Offline
                        Otis
                        Great ideas all. Looks like I got some homework to do.
                        • X Offline
                          xrok1
                          you could also do the 2d thing, then P/P then ctrl P/P, then delete faces on top and edges on bottom (not necessary). of course it helps to have selection toys plugin for this method.
                          “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
