    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      @bob james said:
      I tried the "similar" tool but that didn't seem to do anything (that I could tell).
      It doesn't currently handle nested components etc. It's very experimental and I've not had time to work more on it. ๐Ÿ˜ž
      @bob james said:
      I can't manually fix it because SU requires unique names.
      Select the component you want in the model - then type into the Ruby Console:
      prototype = Sketchup.active_model.selection[0].definition
      Select one or more of the instances of the definition you want to replace - then:
      Sketchup.active_model.selection.each{|e|e.definition=prototype}
      (Make sure the components axis are place identically.)
        rocorona
        --Select the COMPONENT you want to replace;
        --Go to the Components Browser:
        --Right-click on the preview of the replacing component;
        --Choose the "Replace selection" command;
        Was this your goal?
        • Bob JamesB Offline
          Bob James
          Was this your goal?
          Thank you for your idea, but I've used the workflow you describe, but it still leaves the names different.
          Goal: Several identical components have different names: I want consolidate all of them into one component and one name.
            dedmin
            I have a problem with this file - when running Cleanup it's says cleaned 12 edges and the next run is the same. Saved, reopened and again - every time Cleanup cleans 12 edges.
            clenaup.skp
              [attachment=0:1ztpects]<!-- ia0 -->clenaup.skp<!-- ia0 -->[/attachment:1ztpects]
              What settings did you use?
                dedmin
                @thomthom said:
                [attachment=1:1nonbopm]<!-- ia1 -->clenaup.skp<!-- ia1 -->[/attachment:1nonbopm]
                [attachment=0:1nonbopm]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1nonbopm]
                  It's the repair edges feature. Some times it tries to repair edges where they don't seem to remain repaired. It's some oddity I've not worked out why it occurs yet. Might be due to small edges or small accuracy issues. The Repair Broken Edges plugin do the same thing.
                    dedmin
                    Thanks - unchecked Repair Split Edges and now it's fine!
                      Note that it's not an error or anything. It's just some edges that SketchUp doesn't heal properly.
                        Bob James
                        Is there a solution to this goal?
                          Work in progress: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143
                          Not sure if it's exactly what you're looking for... ?
                            shoeb_cars
                            till recently i was using cleanup3 in SU7 but it was a bit slow so i stuck to ur first version which is mighty fast and doesnt ask too many questions. but i recently migrated to SU8 in which cleanup1 doesnt work so then i tried cleanup3... and i just bloody fell in love with it. it is fast and damn, is it clean. as always thom thom "U da MAAAN"
                              I'm guessing you had "Erase Duplicate Faces" checked - which is very slow.
                              • marleusM Offline
                                marleus
                                Thanks ThomThom ๐Ÿ˜Ž
                                I do a lot of 3ds-import and conversions and your ruby really
                                speeds up my work and reduces file size ๐Ÿ˜
                                I ove you one ๐Ÿ˜„
                                Markus Sillander
                                Vantaa, Finland
                                I'm on FormFonts now
                                http://www.formfonts.com
                                • P Offline
                                  publied
                                  very nice and very very useful. thanks theo
                                  hire me@ http://www.publied.it !
                                    LannorMov
                                    Thomthom, yo veo ese plugin como muy pesado ๐Ÿ˜Ž ยฟno te parece? o es que la mรกquina en la que hiciste el vรญdeo es de poca capacidad?
                                    Es solo una apreciaciรณn, no lo tomes a mal.
                                      ke?
                                        LannorMov
                                        @thomthom said:
                                        ke?
                                        Thomthom, I see this plugin is heavy is, or not? or is the machine where you made the video that is of capacity limited?
                                        It's just an appreciation, not take it personal.
                                          The model I used was a very heavy model. Lots of geometry. I used it as an example to show how fast the plugin worked even on very large models. ๐Ÿ˜’
                                            LannorMov
                                            ok, thanks, I installed it and it works great.
                                            Thanks you mate
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 48
                                            • 49
                                            • 17 / 49
