    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      dedmin
      I have a problem with this file - when running Cleanup it's says cleaned 12 edges and the next run is the same. Saved, reopened and again - every time Cleanup cleans 12 edges.
      clenaup.skp
        [attachment=0:1ztpects]<!-- ia0 -->clenaup.skp<!-- ia0 -->[/attachment:1ztpects]
        What settings did you use?
          dedmin
          @thomthom said:
          [attachment=1:1nonbopm]<!-- ia1 -->clenaup.skp<!-- ia1 -->[/attachment:1nonbopm]
          [attachment=0:1nonbopm]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1nonbopm]
            It's the repair edges feature. Some times it tries to repair edges where they don't seem to remain repaired. It's some oddity I've not worked out why it occurs yet. Might be due to small edges or small accuracy issues. The Repair Broken Edges plugin do the same thing.
              dedmin
              Thanks - unchecked Repair Split Edges and now it's fine!
                Note that it's not an error or anything. It's just some edges that SketchUp doesn't heal properly.
                • Bob JamesB
                  Bob James
                  @bob james said:
                  Goal: Several identical components have different names: I want consolidate all of them into one component and one name.
                  Is there a solution to this goal?
                    Work in progress: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143
                    Not sure if it's exactly what you're looking for... ?
                      shoeb_cars
                      till recently i was using cleanup3 in SU7 but it was a bit slow so i stuck to ur first version which is mighty fast and doesnt ask too many questions. but i recently migrated to SU8 in which cleanup1 doesnt work so then i tried cleanup3... and i just bloody fell in love with it. it is fast and damn, is it clean. as always thom thom "U da MAAAN"
                        I'm guessing you had "Erase Duplicate Faces" checked - which is very slow.
                        • marleusM
                          marleus
                          Thanks ThomThom 😎
                          I do a lot of 3ds-import and conversions and your ruby really
                          speeds up my work and reduces file size 😍
                          I ove you one 😄
                          Markus Sillander
                          Vantaa, Finland
                          I'm on FormFonts now
                          http://www.formfonts.com
                          • P
                            publied
                            very nice and very very useful. thanks theo
                            hire me@ http://www.publied.it !
                            • L
                              LannorMov
                              Thomthom, yo veo ese plugin como muy pesado 😎 ¿no te parece? o es que la máquina en la que hiciste el vídeo es de poca capacidad?
                              Es solo una apreciación, no lo tomes a mal.
                                ke?
                                • L
                                  LannorMov
                                  @thomthom said:
                                  ke?
                                  Thomthom, I see this plugin is heavy is, or not? or is the machine where you made the video that is of capacity limited?
                                  It's just an appreciation, not take it personal.
                                    The model I used was a very heavy model. Lots of geometry. I used it as an example to show how fast the plugin worked even on very large models. 😒
                                    • L
                                      LannorMov
                                      ok, thanks, I installed it and it works great.
                                      Thanks you mate
                                        # 3.1.4 - 16.05.2011
                                        #    * Added error detection for merge faces.
                                        #    * Added validation for merge faces to avoid geometry loss.
                                        #    * Added result feedback to Ruby Console for each standalone operation.
                                        #    * Fixed namespace compatibility with TT_Lib 2.5.4
                                        #    * Fixed merge similar material but - now compare alpha
                                        #    * Changed "Lonely Edges" to "Stray Edges"
                                        Requires TT_Lib 2.5.4
                                        • L
                                          LannorMov
                                          What is this? I do not understand
                                            Essahú
                                            If you read the Cleanup download page it says that it also needs the extra 'Lib' files - there is even a link to the thread from where you can download that 'Lib' files folder...
                                            Go back and look for it, get the zip-file, extract its folder and put that into Plugins... fixed! 😒
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 48
                                            • 49
                                            • 17 / 49
