    [Plugin] CleanUp
    974 Posts 217 Posters 893.0k Views 217 Watching
      JPMays
      Oops, I must have saved over the model that was having the problems. Sorry.
      Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
        Well, at least I managed to reproduce the most critical. Disappearing geometry is much worse than some bits that remain.
          JPMays
          Ok, I sent you a cleaned up version of the file, with reduced geometry (I deleted a lot to reduce file size). Still getting the same problem.
          I want to merge these two faces:
          http://img62.imageshack.us/img62/5557/14488237.jpg
          But when I select them, then go here:
          http://img546.imageshack.us/img546/4679/91470050.jpg
          I get nothing. But if I delete one edge, they become a single face, so you know they are co-planar:
          http://img251.imageshack.us/img251/4448/29294919.jpg
            That's because one of them got a material applied to its backside. Tick the Ignore Materials checkbox and it'll merge them.
              JPMays
              I had thought something like that might be the issue, and so I selected everything and applied a uniform material. I even did Reverse Faces to make sure everything was the same. I also used cleanup to set everything to Level 0, but still couldn't get them to merge.
                But you get them to merge when you tick Ignore Material, right?
                Btw, I think I've trapped the case where faces disappear. Will post an update later this week.
                  JPMays
                  Aha, yes it worked! Thanks Thom.
                  • N Offline
                    nosehair
                    thank you!it's very useful!
                    • F Offline
                      firebert85
                      i loaded this plugin into sketchup 8 and its not working, gives me an error message at startup and the plug in cant be found.
                        We are not psychics - please post the error message. So far it suggests you have not installed things properly. Can you confirm what files were put in what folders, and the TT_Lib you installed etc...
                        • utilerU Offline
                          utiler
                          You sound like I feel, TIG! Bloody big weeks' work and you still get asked silly questions..... ๐Ÿ˜ฎ
                          Just Curious...
                          • F Offline
                            firebert85
                            jesus you make it sound like its rocket science.
                            Error Loading File tt_cleanup.rb
                            no such file to load -- TT_Lib2/core.rb
                            its the one file posted on the board, and its in the google sketchup 8 plugin folder.
                            like every other plugin ive downloaded from this website.
                              It seems that TIG was right and you did nt install TT_Lib (another required plugin) as suggested in the plugin post. Please, make sure that is also installed and restart SU.
                                The error message tells you/us what is missing...
                                Many of the more complicated scripts have 'Libraries' of additional functions, that they sometimes share with other tools written by the same author. Many of thomthom's tools use his 'TT_Libs'...
                                It was explained that you need this addition stuff and clearly linked in the thread from where you got the main .rb file...
                                http://forums.sketchucation.com/viewtopic.php?p=193587#p193587 Capture.PNG
                                  risoto1978
                                  I tried to install the cleanup ruby file on my mac. But then starting sketchup I got this error message: "no such file to load -- TT_Lib2/core.rb" but this one was not part of the download.
                                  somebody can help?
                                  risoto
                                    Hi Christian (and welcome),
                                    Please, go back to the first post and follow the link to that TT_Libray (and additional plugin package) you also need for this (and some other) plugin(s) to work.
                                      Christian
                                      Follow Gaieus's advice and mine in the post just before yours ๐Ÿ˜• http://forums.sketchucation.com/viewtopic.php?p=316703#p316703 that shows the link... ๐Ÿ˜’
                                        risoto1978
                                        Thanks for the hint. Reading makes things easier. Now it works.
                                        cheers
                                        risoto
                                          JasonDoggart
                                          Thanks so much for this tool! All your hard work is greatly appreciated!
                                          • Bob JamesB Offline
                                            Bob James
                                            I wound up in a complex model with several instances of a component having two or three different names. I want to change it so that all of the components that are physically the same become just one component and one name.
                                            I tried the "similar" tool but that didn't seem to do anything (that I could tell).
                                            I can't manually fix it because SU requires unique names.
                                            Any advice?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 48
                                            • 49
                                            • 16 / 49
