    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Jeff's stoopid questions (new Q- oct 21,09)
    extensions
    23 Posts 4 Posters 2.6k Views 4 Watching
    • jeff hammondJ Offline
      jeff hammond
      i have indigo now.
      also, i have an avenue of income that opened up in which i'll need to produce some nice renders.. i'm pretty sure i could fake my way through it (and i've already done that once 😄 ) but i'd really like to learn the ins and outs of rendering even if only for my personal satisfaction..
      i'm sure i'll have a bunch of stupid questions to ask along the way so i'm starting this thread to keep it all compiled instead of littering the forum with individual posts..
      so yeah, any help will be much appreciated..
      [going to bed now but i'll put up a couple of questions in the morning]
      dotdotdot
        jeff hammond
        i guess i'll start off asking about texturing.. i can sort of get my head around up close shots but my problem seem to come when doing big areas from far away..
        take a 15,000 sq ft concrete slab for instance (or maybe a lawn).. a straight grey color doesn't look as good as i want it but it looks better than using tiling textures which from a distance look plain awful..
        anyone have any suggestions on dealing with this?
        dotdotdot
        • E Offline
          Ecuadorian
          Our friend Teófilo (Teofas) has a nice way of fighting plain surfaces in renders. He blends a texture in post-processing:
          http://www.sketchupartists.org/?page_id=1972
          -Miguel Lescano
            jeff hammond
            Ok, I'm into that. My cocern was that all the concrete textures I seem to find are just close ups which either tile horibbly or just look way too blown up. Just barely letting a little of that texture through seems to solve both of these issue.
            Building on that.. Could he of made the blend beforehand and achieved the same result? (ie- make the texture in PS then import to Su prior to rendering? The reason I ask is because I foresee myself doing mutliple scenes and it seems like it would be faster to make the texture once so it's already done once I get to PS.
            Indigo specific- how about doing the blending there?
            (and really, I'm going to try all the methods. Rather not reinvent the wheel though 😄
            dotdotdot
              remus
              have a look here: http://www.cgtextures.com/ for good high res concrete textures, they generally need some cleaning up in photoshop, though.
              i imagine with a bit of ps work you could blend a few of them together to form one huuuuuuuge texture and hopefully avoid too much tiling. Be careful to set it to an external texture in skindigo, though, otherwise sketchup will downsize your lovely large texture.
              re blending in indigo, much easier to blend in ps.
              • E Offline
                Ecuadorian
                I guess another way is right click > create unique texture and then add anything you want in an external editor, before rendering. This should save hours of post-processing. 😎
                -Miguel Lescano
                  jeff hammond
                  this is some asphalt i tried to make using a mid grey background with a concrete texture @ ~8% opacity.. so far, it's looking better than any prepackaged ashpalt i've tried at this scale (about 40' across this picture).. i'm going to try another one in the morning with a little less opacity and maybe a local contrast adjustment on the texture prior to blending (USM 25%,35,0 or so) i feel like the details in the asphalt should finer and sharper when viewed from this distance but so far, teofas' technique is looking promising.. of course, this could be from improper importing into indigo or something.
                  i'm super hyped on the film options in indigo.. this is using the kodachrome (r.i.p. 😄 ) setting and it's pretty true to shooting slide in that the dynamic range is so narrow.. hyper contrast with no post work (this is straight out of indigo except for converting to sRGB for the web.. is there a way to attach color profiles straight from indigo?).. i do think they need to change how the white balance settings are controlled but i might post about that in whaat's feature request thread at indigoforums.
                  [click pic for larger]
                  dotdotdot
                    jeff hammond
                    thanks for the link remus.. looks like a good source!
                    well that's good to know. but, i'm not quite sure i understand.? are you saying sketchup will compress the file bytes wise and kill the quality or something else?
                    also, when you say to set it to external, do i do this via the albedo settings? i tried it like that and SU made it to 10"x10" tiles (and i was using a 2500px square photoshop output.) it seems that the quality was lessened but i was using a nearly detail-less texture that it was hard to tell.. i'll try again with something with more detail in the morning.
                    or do i have the wrong idea about albedo altogether?
                    thanks
                    dotdotdot
                      jeff hammond
                      oh, in case you're wondering what you're looking at there, it's an idea for a sculpture.. (for the public to enjoy and skateboarders to love 😄)
                      just messing around with lights.. backgrounds are ruining things for me atm so i'm keeping the scenes super simple.. i'm going to hold of a little before i start bugging you guys about that stuff 😄
                      dotdotdot
                        remus
                        Asphalts looking good 👍
                        With large textures, sketchup will downsize them to the maximum size your graphics card can handle, or if you dont have that option ticked in openGL it'll downsize them to 1024x1024, so basically you can lose a lot of detail.
                        To use an external texture, i think the easiest thing is to import the texture in to SU just so you can sort out the UVing (i.e. how the texture is positioned), then go to the material editor, make sure your in the advanced UI mode (press the ui button if your not), then select 'external' in the albedo drop down. You then need to click new and navigate to where your large texture is.
                          SU will display a max 1024x1024 version in the viewport - but Sketchup will store the original size in the model. So if when the renderer extracts the bitmap it should be the original large version.
                          • E Offline
                            Ecuadorian
                            At least with the latest version of Skindigo, I don't have this problem. Skindigo just "passes through" the full-res texture to Indigo, no matter how ugly the texture looks in your SketchUp viewport. I just tested with a 3087x2426 texture, no problem.
                            -Miguel Lescano
                            • E Offline
                              Ecuadorian
                              This is a bit off topic, but in SketchUp 7, you can display textures at their full resolution in the viewport, too. Just check the "maximum texture size" box in Preferences > OpenGL. This is useful when tracing CAD drawings that have been converted to huge images. 😄
                              A test with a 3087x2426 image. Very zoomed in.
                              -Miguel Lescano
                                remus
                                I wonder what the point in having external textures is, then? other than to cut down on the skp file size. Seems a lot of hassle setting them up for very little gain.
                                  Not full resolution, just upped to max 2048x2048.
                                    jeff hammond
                                    good to know, thanks.
                                    thom, are you saying they will only be displayed in the viewport at 2048 and still be exported to indigo at full rez (if for example i had a 4000px texture).
                                    or, if i bring them in through SU, they will stay at 2048 throughout the rest of the process?
                                    [either way, 2048 is nice enough for my purpose at the time being so i'll just try making the textures at that size]
                                    dotdotdot
                                      Not sure how Indigo does it.
                                      I only use V-Ray.
                                      Sketchup materials usually keep a reference to where the texture was loaded from. (not always)
                                      V-Ray tried to load this.
                                      If the file isn't found it will extract the embedded version in SU
                                      If you right-click a SU material and choose Export Texture it'll export the original sized texture.
                                      Very large textures makes SU very sluggish - so I try to use low res in SU, 512-1024 and link to large res. (Also, we often have multiple variants of a model/project - keeping the SU filesize low adds up - plus it makes it easier to email to clients if needed.)
                                        jeff hammond
                                        oh, ok.. that sounds good and i think indigo can work like this as well if desired.. keep max texture size turned off in SU but link to the full rez in skindigo..
                                        dotdotdot
                                          jeff hammond
                                          here's some grass and concrete.. the concrete had a 2% opacity which obviously isn't enough and the grass turned out decent (which is actually 5 photos worth of different grasses in order to try to randomize it)..
                                          but yeah, this is solved for me and it's just a matter of finding the right photos to make the textures with.. so moving on..
                                          Environment Maps (at least that's what they're called in skindigo) -- are these supposed to be used for the lighting only or are they supposed to be used for the light and the actual image?.. lighting wise, i've had some very nice results from using the hdri files (well, converted to exr) but the backgrounds look very bad (way out of scale and impossible (for me) to line up properly.. What are some of the common reasons for using these? i really want to use them for some of the results i've had but something has to be done about the way i'm using them.
                                          also, the sun + sky setting: what's the difference between the two? my guess is this and i haven't experimented at all with putting them on different layers yet but..
                                          the sun produces the direct style hard light and the sky is more of an all encompassing ambient light..?? i can make softer shadows (actually, fill in some shadows with light) by adding more skylight ??
                                          also, is the light emitted by the sky the same color as my SU background color? or sky? (just say for instance i would like red ambient lighting.. can i control this via my background or sky color in SU.. if so, is it typical to have that set to white?)
                                          dotdotdot
                                            remus
                                            Envionment maps are meant to be used as a backdrop as well as lighting, and i feel your pain in finding appropriately scaled ones. In my experience youve got to look pretty hard to fins anything half decent(and i'll eb dammed if i can remember where i got half of mine from.) You'll probably have more luck if your willing to fork out some dough for a pack or two.
                                            As for getting them properly rotated ive always done it through trial and error, i suppose it depends how accurate you need to be.
                                            Another quick thought: if youve got a camera that can shoot RAW you could probably make your own .exrs, not sure how hard t is to stitch the together properly, but im sure theres a few tutorials out there.
                                            • 1 / 2
