    [REQ] replace construction point with component
    10 Posts 6 Posters 2.2k Views 6 Watching
    • djohnson.nzD Offline
      djohnson.nz
      Hi all,
      I am looking for a plugin that will replace selected construction points with a component.
      Anyone know of one.
      Cheers.
      nO fiKst ideas
        Jackson
        Better post ruby requests in the Ruby discussions forum (add [Request] to the topic title so people know you're requesting something rather than offering).
        http://forums.sketchucation.com/viewforum.php?f=180
        Jackson
        • E Offline
          Ecuadorian
          Could you give us an idea of the intended use? You could simply make that construction point a component itself and then right click > Reload component.
          -Miguel Lescano
            Imagine he has a set of construction points (imported) as place-holders for trees for instance. Now he wants to turn them into instances of the same component definition and yes, indeed, for the same reason; to be able to reload these construction point-components with real trees.
            (Do I get a beer if I guessed correctly?)
            Edit - as Jackson said, there is more chance for something in the ruby forum so I am moving the topic).
            • honoluludesktopH Offline
              honoluludesktop
              Assuming that you do not already have the points located, you can also make a point into a component, and insert it from the the component's menu. When you are done, "edit component" one of the component points, and insert your component into it.
                djohnson.nz
                you have earned yourself a light beer Gaieus,
                I am working with LIDAR information which gives me a point cloud and I want to represent the trees in the park. I would like to select a tree and replace the construction points with leaf components. (probably just green diamonds) A large tree contains about 450 construction points. This would give me an accurate representation of the canopy. If I was to make each construction point a component then replace them I would have to make 450 separate points into components (no thanks)then replace them. A script which simply replaces the selected construction points with the selected component would do that nicely. A script which relaces the component points and aligns the component to radiate away from a central point would be awesum.
                Cheers.
                nO fiKst ideas
                  djohnson.nz
                  Thanks for that code Tig. I will give that a try as soon as I have some time to experiment. Always wanted to have a go at scripts so nows my chance.
                  nO fiKst ideas
                    def cpoints2components()
                      model=Sketchup.active_model
                      ents=model.active_entities
                      ss=model.selection
                      instance=nil; cpoints=[]
                      ss.each{|e|
                        cpoints<<e if e.class==Sketchup;;ConstructionPoint
                        instance=e if e.class==Sketchup;;ComponentInstance
                      if not instance or not cpoints[0]
                        UI.messagebox("Must select an Instance of a Component and at least one Cpoint.")
                        return nil
                      end#if
                      model.start_operation("cpoints2components")
                      cpoints.each{|cpoint|
                        tr=Geom;;Transformation.new(cpoint.position)
                        ents.add_instance(instance.definition,tr)
                      model.commit_operation
                    end#def
                    Copy this into a file called cpoints2compos.rb in the Plugins Folder.
                    Select your Cpoints and one Instance of the required Component, type/paste cpoints2components into the Ruby Console and it should swap them around. [Menu is easy too but I'll leave that to you...]
                    Cpoints are also left behind ... Delete Construction Geometry to erase them or tweak the code to erase! them afterwards...
                      Looking forward to the results - really curious how it works.
                        djohnson.nz
                        Hi there,
                        Just got back to this today.
                        The code worked really well thanks Tig.
                        Attached is the sketchup file I used to create the trees from LIDAR
                        Its a bit fiddly but the result could be useful.
                        More could be done to change the nature of the component to get a feel for different tree types.
                        Use the layers to turn off the constructino points to see what the trees look like. Note I havent done all the trees.
                        I added very basic lines as trunks and this helps visualise the tree a bit better.
                        Remember these are New Zealand trees so they might look different to yours.
                        Cheers.
                        SU7.1 file
                        nO fiKst ideas
