    Problem running IRender after loading Twilight.
    extensions
    28 Posts 8 Posters 5.4k Views 8 Watching
    • Al HartA Offline
      Al Hart
      @chris_at_twilight said:
      Certainly Twilight is not actively impacting it.
      With Twilight not loaded, it looks for arobjects.dll in:
      c:\Program Files\Google\SketchUp 7, --- then in
      c:\Windows\system32
      c:\Windows\system
      c:\Windows, --- and then in the current folder,
      c:\Program Files\Render Plus Systems\IRender_nXt\bin_nxt
      (where it finds it)
      With Twilight loaded, it looks in
      c:\Program Files\Google\SketchUp 7\Twilight, --- then
      c:\Windows\system32
      c:\Windows\system
      c:\Windows,
      but never in c:\Program Files\Render Plus System
      Does Twilight make a ruby call, or a Windows call, to change the DLL search path?
      (I am wondering because it looks in the twilight folder before the windows folder)
      If so, then we could make a similar call to add "c:\Program Files\Render Plus Systems\IRender_nXt\bin_nxt" to the DLL search path.
      Thanks,
      Al Hart
      IRender nXt from Render Plus
        Chris_at_Twilight
        Thanks,
        Yes, exactly. If you set your search path immediately before loading the dll, that should resolve the problem. This is probably a good idea no matter what because, according to Microsoft, the DLL search that is finding the arobjects.dll is looking in the "current path". Since many things can influence the current path, it's probably not safe to rely too much on it.
        I've added code to Twilight to restore the "default" search path immediately after loading the dll, and that seems to work well, so I suggest doing that also.
        http://www.TwilightRender.com
        • Al HartA Offline
          Al Hart
          I presume you are doing this in Ruby.
          I suspect you are not restoring the search path, because Twilight still seems to be in it when IRender nXt is trying to load its DLL.
          Can you send the two lines of Ruby code? (set path and restore path).
          I want to see why the restore path is (apparently) not working.
          Al Hart
          • Al HartA Offline
            Al Hart
            Thanks for your help on this, we are setting ENV["PATH"] before loading the DLL and it seems to work better now.
            Al Hart
              Chris_at_Twilight
              Sorry for the confusion. I meant, with the next release, this will be added. The current publicly available release does not 'reset' the dll search path.
              The code I'm using is Windows API. SetDllDirectory (more on it here: http://msdn.microsoft.com/en-us/library/ms686203%28VS.85%29.aspx)
              • Al HartA Offline
                Al Hart
                AHA.
                I turns out that we were using SetCurrentDirectory() to define the DLL path, and depending on the LoadLibrary defaults which include the current directory.
                When you call SetDllDirectory(), with a path name, the current directory is no longer used, so our logic no longer worked.
                If you had called SetDllDirectory() again with a blank name to reset it, then the current directory logic is restored. So that is what was causing the original problem.
                We are going to switch to using SetDllDirectory() ourselves, which will eliminate this problem, but we both need to be carefull to reset it so we don't mess up anyone else who is depending on the current directory method of loading DLLs
                Al Hart
                  Chris_at_Twilight
                  My suggestion exactly. It's already been implemented in Twilight and will be in place in the next release.
                  • Al HartA Offline
                    Al Hart
                    We have released new versions of IRender nXt which fix this problem.
                    Thanks for your help Chris.
                    Al Hart
                    • 2 / 2
