    Problem running IRender after loading Twilight.
    extensions
    28 Posts 8 Posters 6.4k Views 8 Watching
    • N
      notareal
      Is this related to http://nxt.accurender.com/forums/t/2645.aspx
      " Hi,
      I just purchased the licence and then followed up to update my previous version with the latest one and since then I seem to be getting this crazy visualc++ bug every time I either try to edit materials or render. I've found for some strange reason that if I use nxt stable edition I can modify the textures but not render and if I use the Beta version I can render but not modify the textures. As I might not be making myself clear I've put a ling to a screencap ... was wondering if it has happened to anyone and if anyone knows how to fix this problem.
      thanks.
      http://www.creationscoquerel.com/irender_bug.jpg
      Filed under: visual runtime error"
      So would the problem be in Visual C++ Runtime, not in .net?
      • N
        notareal
        Beated me, Chris. Good old dll hell.
        • Al HartA
          Al Hart
          " Hi,
          I just purchased the license and then followed up to update my previous version with the latest one and since then I seem to be getting this crazy visual c++ bug every time
          Is the problem you are having related to twilight, or is it a completely different problem.
          If you have twilight installed, rename the .rb file to a different extension, and see if that fixes your problem. If you do not have it installed, then this is a different problem, and we will have to find a different fix for it.
          Al Hart
          IRender nXt from Render Plus
          • Al HartA
            Al Hart
            @chris_at_twilight said:
            When I installed the demo for IDX, it installed the Visual C++ 2005 runtime dll's. Twilight uses the 2008 dll's. I've never encountered (I think) an application with plugins using separate VC++ dlls so I don't know that this is the cause...actually I kind of expect it should work but Microsoft made such big changes with SxS etc... who knows.
            We'll try to help solve this too. We have no intention of conflicting with any other software.
            I'm sure you meant IRender, and not IDX.
            This may be a MSVC 2005 vs MSVC 2008 problem. If so, that will be unfortunate, but hopefully we can work out a fix. We thought it was related to .NET, but it may be the 2005 DLLs instead.
            Thanks for taking a look at it for us.
            [Edit] Also, our other applications, using a similar 2005 DLL work OK with Twilight loaded. So it is something about the rendering application which is interfering.
            Al Hart
            • N
              notareal
              @al hart said:
              " Hi,
              But I though that was MSVC 2005 vs MSVC 2008 problem, so basically the same that with Twilight? So you never did go to MSVC 2008... or is there some other dll that might conflict, like freeimage? Anyhow perhaps you should continue solving this private.
              • C
                Chris_at_Twilight
                I ran SketchUp through ProcMon to watch what libraries are getting loaded when NXT works and when it doesn't. It appears that when it doesn't work, Windows is unable to locate the arobjects.dll. Why having Twilight running makes any difference for that, I can't imagine. Certainly Twilight is not actively impacting it. It doesn't appear to be a VC++ problem either (thought I'm not certain), as you can see the 2005 (VC8) dlls are loaded in the images.
                Sorry, yes, I meant IRender.
                Twilight not running
                Twilight running
                http://www.TwilightRender.com
                • Al HartA
                  Al Hart
                  Thanks Chris,
                  This could be a big help. It may be something simple, like that the problem is that the Twilight DLL is changing the default folder in Windows, and we just need to change it back before loading our DLL.
                  Al Hart
                  • C
                    Chris_at_Twilight
                    I think I've got it. Twilight adds it's own directory to the DLL search path. According to Microsoft documentation, simply adding a directory to the search path (not changing, just adding), switches the DLL search mode from "Default". Probably IRender is not setting it's own search paths, but relying on the "default". You can see more about it here: http://msdn.microsoft.com/en-us/library/ms686203%28VS.85%29.aspx
                    I've modified Twilight to restore the "default" search mode and IRender works after that. However, if there are any plugins loaded before Twilight who are using a modified dll search path, switching to "default" mode can impact them in the same way. So either way, there is no really "safe" method. One way or the other has a potential to impact other plugins. As notareal said, dll hell.
                    I guess the best "safe" practice is to set your own dll search path, load your dll, then restore to the default. If everyone did that it would probably avoid all these issues.
                    • Al HartA
                      Al Hart
                      With Twilight not loaded, it looks for arobjects.dll in:
                      c:\Program Files\Google\SketchUp 7, --- then in
                      c:\Windows\system32
                      c:\Windows\system
                      c:\Windows, --- and then in the current folder,
                      c:\Program Files\Render Plus Systems\IRender_nXt\bin_nxt
                      (where it finds it)
                      With Twilight loaded, it looks in
                      c:\Program Files\Google\SketchUp 7\Twilight, --- then
                      c:\Windows\system32
                      c:\Windows\system
                      c:\Windows,
                      but never in c:\Program Files\Render Plus System
                      Does Twilight make a ruby call, or a Windows call, to change the DLL search path?
                      (I am wondering because it looks in the twilight folder before the windows folder)
                      If so, then we could make a similar call to add "c:\Program Files\Render Plus Systems\IRender_nXt\bin_nxt" to the DLL search path.
                      Thanks,
                      Al Hart
                      • C
                        Chris_at_Twilight
                        Thanks,
                        Yes, exactly. If you set your search path immediately before loading the dll, that should resolve the problem. This is probably a good idea no matter what because, according to Microsoft, the DLL search that is finding the arobjects.dll is looking in the "current path". Since many things can influence the current path, it's probably not safe to rely too much on it.
                        I've added code to Twilight to restore the "default" search path immediately after loading the dll, and that seems to work well, so I suggest doing that also.
                        • Al HartA
                          Al Hart
                          I presume you are doing this in Ruby.
                          I suspect you are not restoring the search path, because Twilight still seems to be in it when IRender nXt is trying to load its DLL.
                          Can you send the two lines of Ruby code? (set path and restore path).
                          I want to see why the restore path is (apparently) not working.
                          Al Hart
                          • Al HartA
                            Al Hart
                            Thanks for your help on this, we are setting ENV["PATH"] before loading the DLL and it seems to work better now.
                            Al Hart
                            • C
                              Chris_at_Twilight
                              Sorry for the confusion. I meant, with the next release, this will be added. The current publicly available release does not 'reset' the dll search path.
                              The code I'm using is Windows API. SetDllDirectory (more on it here: http://msdn.microsoft.com/en-us/library/ms686203%28VS.85%29.aspx)
                              • Al HartA
                                Al Hart
                                AHA.
                                I turns out that we were using SetCurrentDirectory() to define the DLL path, and depending on the LoadLibrary defaults which include the current directory.
                                When you call SetDllDirectory(), with a path name, the current directory is no longer used, so our logic no longer worked.
                                If you had called SetDllDirectory() again with a blank name to reset it, then the current directory logic is restored. So that is what was causing the original problem.
                                We are going to switch to using SetDllDirectory() ourselves, which will eliminate this problem, but we both need to be carefull to reset it so we don't mess up anyone else who is depending on the current directory method of loading DLLs
                                Al Hart
                                • C
                                  Chris_at_Twilight
                                  My suggestion exactly. It's already been implemented in Twilight and will be in place in the next release.
                                  • Al HartA
                                    Al Hart
                                    We have released new versions of IRender nXt which fix this problem.
                                    Thanks for your help Chris.
                                    Al Hart
                                    • 2 / 2
