    Which are your favourite plugins?
    11 Posts 10 Posters 1.2k Views 10 Watching
    • coulteriC Offline
      coulteri
      Hello! Which plugins do you use most? I´m landscape architect and use e. g. these ones:
      sandbox, scale and rotate multiple, component spray tool, weld, copy along path, pipe along path, rooftool, joint-vector-normal push/pull, tools on surface, freescale, bezier spline curves, FFD, improved selection tool, Kerkythea exporter...
      And what about you? 😄
      coulteri
        remus
        Anything from fredo 👍
          Favourite and most-used isn't the same in my case.
          My most used would be my own Selection Toys plugin. I've got the selection filters for Faces, Edges, Groups and Components assigned to hotkeys and I use them regularly all the time as I model.
          My favorites would be TOS, JPP, SSB, Round Corners and FredoScale and Profile Builder.
            For the fun:
            Protrude by Jim Foltz + Grow by Tig + Random Painter by Chris Fullmer + Twilight 😎
            • coulteriC Offline
              coulteri
              Yes, I also use your selection toys and thank you for it... 😄
              • JClementsJ Offline
                JClements
                Most dependent upon:
                Weld
                PipeAlongPath
                Guide Point at center of Selection (can't remember the ruby name)
                Soon to be: 2D Tools
                • E Offline
                  Ecuadorian
                  The ones that do not clutter my context menu.
                  -Miguel Lescano
                    dedmin
                    Every couple of seconds I press "N" - my shortcut for the "Get Dimensions" plugin
                    • soloS Offline
                      solo
                      Mine are:
                      TOS, JPP, SDS, Fredoscale, Round corners in 3D, Purge all, Extrude lines vector by 2 points, weld, Bool tools.
                      http://www.solos-art.com
                      • K Offline
                        Khai
                        whatever I need for that job at the time 😉
                        • jeff hammondJ Offline
                          jeff hammond
                          Arc: Center and Two Points
                          Weld
                          Perpendicular Face Tools
                          Arc Centerpoint Finder -or- Arc Centerpoint
                          Invert Selection
                          Skindigo
                          Joint Push/Pull
                          Bend (FredoScale)
                          BoolTools
                          (Selection Toys? what's that.. sounds like it could easily be added to this list if it can do what i hope it can 😄 )
                          dotdotdot
