    Imported images vs textures
    8 Posts 4 Posters 1.1k Views 4 Watching
    • honoluludesktopH
      honoluludesktop
      I have been building 2d face me people with png files (imported as images, not textures) when it was brought to my attention that by using a texture, the component image could be bumped for greater realism. So I took one my 2d components, removed the existing image on the face, and replaced it with a texture. I had problems scaling, and aligning things up, but when I bumped, and rendered, the rendered image had better 3d effect. Problem is that the rendered colors now look washed out. I previously read some where that compressed images sometimes have problems with gamma correction when they are rendered, so I atempted to adjust the texture's gamma setting prior to rendering. No luck. Anyone with advice, or suggestions?
      • R
        remus
        Which render engine are you using?
        • honoluludesktopH
          honoluludesktop
          IDX Renditioner. Their engine is lightworks.
          • jeff hammondJ
            jeff hammond
            sounds similar to mismatched color profiles..
            if a picture is saved in adobe98 (for example) and then viewed in a browser that can't read profiles, the image will appear washed out.. this is why you should generally save all your web stuff in sRGB -- most browsers are displaying in sRGB (while others can read any profile.. safari being one)..
            anyway, try saving the texture with an sRGB profile (or sRGB IEC61966-2.1 if that option is available in your editing app)..
            if need be, post the picture here and i can convert it for you..
            dotdotdot
            • E
              Ecuadorian
              Could you please post a "before and after"? I have an idea from my past experience with 3dsMAX.
              -Miguel Lescano
              • honoluludesktopH
                honoluludesktop
                No before, guess I inadvertantly wrote over. After below:
                • E
                  Ecuadorian
                  This looks like a problem of overexposure, not gamma. Try lowering the sun intensity.
                  -Miguel Lescano
                  • honoluludesktopH
                    honoluludesktop
                    Miguel, Helped a little. Guess before I can be sure, I must rebuild the component.
