    How to mirror an object in sketchup???
    7 Posts 7 Posters 9.8k Views 7 Watching
      anees
      hi all.....i would like to know how to mirror an object in sketchup without ruby....in pure sketchup....thx....
      • honoluludesktopH Offline
        honoluludesktop
        Select the entity, then use the scale tool, to drag the handle perpendicular to the axis you wish to mirror until the scale on the bottom bar changes from 1.00 to -1.00.
          dedmin
          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Mirror_31.rb
          [mod=:l2hx9pq9]This is VERY out of date - see this version:
          http://sketchucation.com/pluginstore?pln=Mirror
          v 6.0 ![/mod:l2hx9pq9]
            d12dozr
            Select object(s) > Right click > Flip along > Red/Green/Blue axis
            http://goo.gl/f7ooYh
              bmscmoreira
              I use the flip along axes tool. (right click the object/group/component, then select flip along, then choose the axis). If the axis is not correct, be sure to first change your user coordinate system, matching you need (also using google default function, no ruby necessary).
              http://www.brunomoreira.net
                djh
                Thank you, d12dozr. Very easy.
                  I use Flip Along often enough I made keyboard shortcuts.
