    No Color Plugin
    15 Posts 7 Posters 1.2k Views 7 Watching
      skeerc
      Looking for a plugin or script which would change a models surfaces to "White" which already have Textures applied (& hopefully including the models Components). Have seen one which reverts back to Greyscale - but is there one which could revert "All" back to White. Thanks
      • E Offline
        Ecuadorian
        Try:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=13192
        or
        http://www.smustard.com/script/RemoveMaterials
        If it's just for visualization purposes and you don't need to permanently change your model, also try color by layer.
        -Miguel Lescano
        • X Offline
          xrok1
          “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          • E Offline
            Ecuadorian
            I should add this to my Duh! list.
            -Miguel Lescano
            • X Offline
              xrok1
              • G Offline
                Or even the Hidden line mode? 😕
                  Jim
                  Yes, but most people are not born with the knowledge - it needs to be learned at some point.
                  • X Offline
                    xrok1
                    toochez` or however you spell too shay? DUH
                      skeerc
                      Thanks for the feedback - using the monochrome setting & editing the style pref to 'White' the model does not print out as white surfaces, choosing the 'No color' from Toolbox does not allow B&W texture to be applied hence the need to Color 'All" white. Any suggestions - the plugins look promising.
                      • X Offline
                        xrok1
                        funny the monochrome thing seems to work here. is this what you're trying to do:
                          "touché"
                          • G Offline
                            @skeerc said:
                            Thanks for the feedback - using the monochrome setting & editing the style pref to 'White' the model does not print out as white surfaces...
                            True that SU will always "shade" every surface a little bit - even with all kinds of shadows off. This is only for giving it a 3D view but if you really mean to have only pure white (255,255,255 RGB) in your prints, you will need to export it as some image and edit everything out.
                              You can set the style to Hidden line and set the Background to white with no Sky or Ground. Then you'll have no shading.
                              • G Offline
                                Yeah, true.
                                (DOH) 😉
                                  Anssi
                                  And in the Shadows dialog, check "Use sun for shading". Now the amount of shading can be controlled by the Light and Dark sliders. Dark=100%>no shading.
                                  Anssi
