    ? [Question] - A Ruby Calculator ?
    40 Posts 12 Posters 36.6k Views 12 Watching
      a4chitect
      perhaps this thread might help
      http://forums.sketchucation.com/viewtopic.php?f=180&t=21281
      put the attached file into plugins folder, no more load errors
      win32ole.zip
      this script sends "20" into sketchup - when vcb is active - this gets put in
      • G Offline
        Gruff
        A4chitect:
        Thanks! It works on my PC now as well.
        Chris:
        There you go. You can write a calculator with a Web page front end that uses code like that in 'test_me.rb' to drive the VCB. That would be a better solution as it would be native to SketchUp for Windows. Much much better than my Compiled app.
        Resistance is .... Character Forming. Grin
        • K Offline
          ktkoh
          This looks like a great tool for me as I need a calculator quite often. The way it seems to work best for me is.
          1. Put the formula in the calculator and press enter once.
          2. Back in SU select the tool ie Move and the handle point then click on the TG Cal and return the mouse to show the move direction and then press Enter.
          Keith
          • X Offline
            xrok1
            running windows7 here.
            “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • G Offline
              Gruff
              Ah! that would be the problem then. Definite version issue.
              Since I do not have Windows7 I cannot say that it will ever work for you.
              Are there modifications you can do to get it to run as though it were launched from WinXP? XP has tools to run older OS products through it's shortcut options.
              Looks nice though. 😄
              • X Offline
                xrok1
                tried it in XP compatibility mode. still crashed,
                • X Offline
                  xrok1
                  arrrrg!
                  • G Offline
                    Gruff
                    Tell you what xrok1,
                    Here is a small Ruby script Calculator that binds to the Tools menu.
                    Bind it to a shortcut key and your in business.
                    [Edit]
                    See the attached zip file two posts down...
                    [/Edit]
                    • JClementsJ Offline
                      JClements
                      Thanks, Gruff!
                        Jim
                        A minor thing - require 'Sketchup' causes sketchup.rb to load a second time. Loading sketchup.rb again doesn't really break anything, but it does create a duplicate Ruby Console entry in the Window menu.
                        It should be - require 'sketchup' (small s)
                        • G Offline
                          Gruff
                          You are really having a bad day, Huh. Sorry for any confusion.
                          Attached is a zip file that contains both ruby_calc.rb and win32old.so.
                          Unzip and place them both in your plugins folder under sketchup.
                          I found it handy to bind the menu 'Tool/Ruby Calc' to a shortcut key. (I use Alt+Q)
                          This calculator doesn't have a history, but it will take any Ruby formatted Math equation and use it to drive the VCB.
                          Latest Ruby_Calc. (This is not TG_Calc)
                          • G Offline
                            Gruff
                            Thanks for the advice Jim.
                            I updated the Ruby_Calc Zip attachment with your change. For any who get this far there are two calculators in this thread.
                            1. TG_Calc.exe which is a Compiled Windows program. It has a number of features.
                            2. Ruby_Calc.rb which is just a simple calc with no features.
                            Both only work with Windows and require the win32ole.so file.
                            both work by pumping keystrokes into the SU environment.
                              JClements
                              I thought this worked. I tried the zip file contents in both SU2013 and SU2014.
                              I also tried installing via the SketchUcation Plugin Store.
                                The script hasn't got require 'langhandler'
                                Add that after the require 'sketchup'
                                If an earlier loading script has already required it it might mask the lack of it.
                                However the line:
                                UI.menu("Tools").add_item($exStrings.GetString("Ruby Calc")) { rubycalc }
                                will also fail if $exStrings is undefined as it loads - as that might get setup by another script too.
                                Frankly I'd forget about the langhandler completely, and change it to read:
                                UI.menu("Tools").add_item("Ruby Calc"){rubycalc}
                                  JClements
                                  Thanks TIG. Works now per your post.
                                  If I wanted to add info to the taskbar below such as:
                                  = Subtract, [
                                  ] = Multiply, [/] = Divide, [%] return remainder, [**] = exponent, [ ( ) ] = group functions"*
                                  what would be the proper ruby format and where should it be inserted?
                                  *# Ruby Calc
                                  by Gruff
                                  Oct 29th 2009
                                  Many thanks to a4chitect for the win32ole section
                                  Ruby Calc is a simple SketchUp for Windows calculator.
                                  Feel free to hack and wack it.
                                  Since it is run as a loose procedure rather than a class
                                  it does not kick SU out of the currently running tool
                                  Bind the Menu Item 'Ruby Calc' to a short cut key
                                  For ease of use. (I use Alt-Q)
                                  require 'sketchup'
                                  [highlight=#ff0000:rs61bj0c]require 'langhandler'[/highlight:rs61bj0c]
                                  require 'win32ole'
                                  def rubycalc
                                  prompt = [""]
                                  default = [" "]
                                  input = UI.inputbox prompt, default, "Ruby Calc"
                                  fanswer = eval input[0]
                                  sanswer = fanswer.to_s + "{ENTER}{ENTER}"
                                  Create an instance of the Wscript Shell
                                  wsh = WIN32OLE.new('Wscript.Shell')
                                  #Try to activate the Sketchup window:
                                  if wsh.AppActivate(' - SketchUp Pro') || wsh.AppActivate(' - SketchUp')
                                  wsh.SendKeys(sanswer)
                                  else
                                  puts "Impossible"
                                  if( not file_loaded?("ruby_calc.rb") )
                                  add_separator_to_menu("Tools")
                                  [highlight=#ff0000:rs61bj0c]UI.menu("Tools").add_item("Ruby Calc")[/highlight:rs61bj0c] { rubycalc }
                                  file_loaded("ruby_calc.rb")*
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    v 2.0.0 cleanup by Dan Rathbun : 16 Aug 2014
                                    1. Module wrapped in Gruff::RubyCalc
                                    2. Method renamed: Gruff::RubyCalc::command()
                                    • statusbar help text displayed during input
                                    • evaluation rescue wrapped with retry
                                    • exits for empty input and cancellation
                                    1. Tweekable text placed in module constants
                                    ruby_calc_2.rb
                                    I'm not here much anymore.
                                      Dan Rathbun
                                      Gruff has not logged in to SCF for a year and 4 months. Is he OK ?
                                        JClements
                                        Thank you for your help, Dan and TIG.
                                          turbodizayn
                                          Hi! Does it work in SU2016 ? I have a message, " Could not activate SketchUp application window."
                                            Dan Rathbun
                                            I just tested version 2 of "ruby_calc_2.rb" in SketchUp 2016, and this works.
                                            Version 2 is in this post:
                                            http://sketchucation.com/forums/viewtopic.php?f=180&t=22660&view=unread#p535117
                                            What is "it" you refer to ?
                                            • 2 / 2
