    Invalid Web Dialog
    10 Posts 5 Posters 2.5k Views 5 Watching
    • C
      cjthompson
      I have been using a web dialog as an interface and lately I've been getting the error "#<Exception: Invalid Dialog>" if I submit more than once. Does anyone know why this is?
      I am using mostly get_element_value instead of parameters.
      • M
        MartinRinehart
        Never saw that. Can you post some code?
        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        • C
          cjthompson
          I've been trying to get a code snippet to replicate the problem, but I haven't been able to. I just wanted to know if anyone else has had this problem.
          • M
            MSP_Greg
            CJ,
            Can you please clarify what exactly you mean by submit? Not sure if you mean HTML form submit or not...
            If you do, I have only used a button onclick event and a trap for escape.
            Greg
            • C
              cjthompson
              sorry, I meant executing window.location = skp:callback_method_name.
              I think this might be an issue with ASP. I haven't been able to replicate it with html.
              • C
                cjthompson
                Okay. This is just plain stupid.
                I stepped through my code to find the problem, and it turns out that somehow creating a new bounding box invalidates my web dialog.
                here is a code snippet to test with (I used the console):
                testWebDialog = UI;;WebDialog.new("Test;",true,"webDAtts",700,500)
                testWebDialog.set_html("<head></head><body>This is a test</body>")
                testWebDialog.show
                puts testWebDialog.visible? #(should return true)
                Geom;;BoundingBox.new
                puts testWebDialog.visible? #(should return false)
                • C
                  cjthompson
                  I noticed that this was fixed in 7.1
                  • thomthomT
                    Good to hear.
                    • J
                      Jim
                      If you create a dialog assigning a @class variable to reference it, and the dialog is closed, then the variable holds a reference to the now invalid dialog.
                      Typical code
                      def create_dialog
                        if !@dlg
                          @dlg = UI;;WebDialog.new( ... )
                        @dlg.show { }
                      Now if the dialog is closed, the @dlg variable still holds a reference to the now invalid dialog. In addition to checking whether the @dlg variable exists, you need to check if the dialog is visible?
                      def create_dialog
                        unless @dlg and @dlg.visible?
                        @dlg.show { }
                      • J
                        Jim
                        Or just recreate the dialog every time...
                        def create_dialog
                          @dlg.show { }
