Invalid Web Dialog
I have been using a web dialog as an interface and lately I've been getting the error "#<Exception: Invalid Dialog>" if I submit more than once. Does anyone know why this is?
I am using mostly get_element_value instead of parameters.
Never saw that. Can you post some code?
I've been trying to get a code snippet to replicate the problem, but I haven't been able to. I just wanted to know if anyone else has had this problem.
CJ,
Can you please clarify what exactly you mean by submit? Not sure if you mean HTML form submit or not...
If you do, I have only used a button onclick event and a trap for escape.
Greg
sorry, I meant executing window.location = skp:callback_method_name.
I think this might be an issue with ASP. I haven't been able to replicate it with html.
Okay. This is just plain stupid.
I stepped through my code to find the problem, and it turns out that somehow creating a new bounding box invalidates my web dialog.
here is a code snippet to test with (I used the console):
testWebDialog = UI;;WebDialog.new("Test;",true,"webDAtts",700,500) testWebDialog.set_html("<head></head><body>This is a test</body>") testWebDialog.show puts testWebDialog.visible? #(should return true) Geom;;BoundingBox.new puts testWebDialog.visible? #(should return false)
I noticed that this was fixed in 7.1
If you create a dialog assigning a @class variable to reference it, and the dialog is closed, then the variable holds a reference to the now invalid dialog.
Typical code
def create_dialog if !@dlg @dlg = UI;;WebDialog.new( ... ) end @dlg.show { } end
Now if the dialog is closed, the @dlg variable still holds a reference to the now invalid dialog. In addition to checking whether the @dlg variable exists, you need to check if the dialog is visible?
def create_dialog unless @dlg and @dlg.visible? @dlg = UI;;WebDialog.new( ... ) end @dlg.show { } end
Or just recreate the dialog every time...
def create_dialog @dlg = UI;;WebDialog.new( ... ) @dlg.show { } end
