    New Version of RPS 3D PDF
    extensions
    1 Posts 1 Posters 503 Views 1 Watching
    • Al HartA
      Al Hart
      Faces in groups or components, which are in Layer0 will display even if Layer0 is turned off.
      When exporting 2 sided faces, both the front and reverse faces materials will be displayed respectively. "Export 2 sided faces" is on the Options/Model tab.
      The model is now drawn to scale, so that the PDF measurement tool in Acrobat will work correctly. You can set the default units to be used for measurement on the Options/Document tab.
      "Fit SketchUp view into U3D area" is now saved into the registry, so that the last setting used will be used for the next new model that is converted.
      We have a feature that automatically sets a maximum zoom factor, so that if a user accidentally zooms out so far that he can't see the model any more, we zoom in close enough so that, at least, they can see the model again. Adding the new feature to keep the model in its original scale broke this. It's working again.
      We also fixed a bug where we weren't scaling textures properly. This only happened for the reverse side of a face in a group with a texture applied to the group, and only if there was a texture appied to the front side of that face. This is working now.
      RPS 3D PDF creates interactive 3D PDF files from SketchUp models.
      For more information see: RPS 3D PDF
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
