    WebDialog help - hide scrollbars
    31 Posts 7 Posters 7.5k Views 7 Watching
    • N Offline
      NewOne
      How can I hide scrollbars in webdialog?
      I tried with CSS overflow:auto; , but this works just if I don't use !DOCTYPE, but I need !DOCTYPE (Transitional) to enable :focus css pseudoelement.
      The vertical scrollbar is there, grayed-oud and taking my pixels abusive. I need that little space 😞
      πŸ’­
      One more thing: JS statement element.selected = true; did not worked on my native SU instalation. After I updated my Internet Explorer from 6 to 7, it did worked... how is this possible, because in SU I still have IE4 ?
        DIEGO-RODRIGUEZ
        try >
        in html, body properties
        <body scroll="no" (l add here other property "color" etc ...)>
        • N Offline
          NewOne
          try >
          Thanks elcorto, the option is working.
          Maybe someone can explain why element.selected = true; doesn't work properly in native SU installation, but after updating IE from 6 to 7 on Windows machine, it is fixed. Is there some JS update? can it be applied without updating IE?
            MartinRinehart
            The second parameter to WebDialog.new, "scrollable" (show scroll bars if true), works correctly for Mac, but does nothing on PC where you get scrollbars unless your HTML/CSS/JavaScript eliminates them.
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
            • Dan RathbunD Offline
              Dan Rathbun
              NewOne, and all ... I found this article on virtuosimedia very informative
              Ultimate IE6 Cheatsheet: How To Fix 25+ Internet Explorer 6 Bugs
              .. in addition the author recommends always using !DOCTYPE, and makes a good case.
              .. other good tips, ie: the CSS Reset Rule.
              have a read y'all !
              I'm not here much anymore.
              • chrisglasierC Offline
                chrisglasier
                css ...
                body{
                border;0px;
                margin;0px;
                overflow;hidden   }
                With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                  Dan Rathbun
                  CSS Attribute overflow:
                  With Internet Explorer 6 and later, when you use the !DOCTYPE declaration to specify standards-compliant mode, this property (overflow ) applies to the html object.
                  1. MSDN Library / CSS Reference: overflow Attribute | overflow Property
                    MartinRinehart
                    @dan rathbun said:
                    NewOne, and all ... I found this article ... very informative
                    Thanks, Dan.
                    So informative, in fact, that it would be nice if you posted a new topic re IE6 Cheat Sheet, or something similar so Google will find it for us.
                      chrisglasier
                      @chrisglasier said:
                      > css ...
                      > body{
                      > border;0px;
                      > margin;0px;
                      > overflow;hidden   }
                      Sorry forgot the pic
                      • N Offline
                        NewOne
                        @chrisglasier said:
                        > css ...
                        > body{
                        > border;0px;
                        > margin;0px;
                        > overflow;hidden   }
                        But you don't use !DOCTYPE, right? πŸ’š Paste this on the top of your Html page and tell me if overflow works for you. Also your window border...
                        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
                          chrisglasier
                          My top:
                          <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
                          <html>
                          <!-- Copyright 2007-9 Chris Glasier -->
                          <!--This follows the Nameset format for easy integration-->
                          <head>
                          <title>Scene machine</title>
                          <LINK href="Scene machine.css" rel="stylesheet" type="text/css">
                          <script type = "text/javascript" src = "javascript/sceneDevice.js"></script>
                          </head>
                          Body css in external file of course.
                            chrisglasier
                            Adding "http://www.w3.org/TR/html4/loose.dtd" looks like this:
                            but the webdialog is on the local drive so I don't see the big deal. But please let me know if there is one!
                            • N Offline
                              NewOne
                              [attachment=0:1ma73d3a]<!-- ia0 -->cgScenes no scroll 002.png<!-- ia0 -->[/attachment:1ma73d3a]
                              Same thing happens to me. So, I used your version of !DOCTYPE πŸ’š
                                Jim
                                Is there a single, simple answer to this?
                                • N Offline
                                  NewOne
                                  Well, I use <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> and <body scroll="no">. This seems to be working in all the cases. Other suggestions are not working if I use !DOCTYPE.
                                  I think this is the universal answer.
                                    I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
                                      chrisglasier
                                      Don't you think in good time such application may well need web connectivity, say, to get or set remote data? Making things comply with today's standards could save future hassles for following generations.
                                        I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
                                        It's not something that will cause problems for future plugins - if future SU corrects the bug, then this little attribute don't do much.
                                          chrisglasier
                                          Ok no big deal except I am working on the API webdialog (which will include snippets). It seems there is a conflict between this:
                                          body{
                                          border;0px;
                                          margin;0px;
                                          overflow;hidden   }
                                          and STRICT doctype, so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
                                          It would be useful for me to understand.
                                          Chris
                                            I don't know why the overflow with STRICT doctype within a Webdialog doesn't work - it's how you do it with websites.
                                            Seeing that the Webdialog has a scroll property for it's creating of the ruby class I'd expect that the scrollbars should be set from ruby. I think that the embedded IE control has a scroll property which developers who wish to embed HTML content can set to a fixed override. Why this argument isn't adhered to, I don't know.
                                            I wonder if the SU dev team has been made aware of the scrollnar bug.
                                            Was it so that this is PC only - that it works as expected on Mac?
                                            • 1 / 2
