    WebDialog help - hide scrollbars
    31 Posts 7 Posters 7.8k Views 7 Watching
      DIEGO-RODRIGUEZ
      try >
      in html, body properties
      <body scroll="no" (l add here other property "color" etc ...)>
      • N
        NewOne
        try >
        Thanks elcorto, the option is working.
        Maybe someone can explain why element.selected = true; doesn't work properly in native SU installation, but after updating IE from 6 to 7 on Windows machine, it is fixed. Is there some JS update? can it be applied without updating IE?
          MartinRinehart
          The second parameter to WebDialog.new, "scrollable" (show scroll bars if true), works correctly for Mac, but does nothing on PC where you get scrollbars unless your HTML/CSS/JavaScript eliminates them.
          • Dan RathbunD
            Dan Rathbun
            NewOne, and all ... I found this article on virtuosimedia very informative
            Ultimate IE6 Cheatsheet: How To Fix 25+ Internet Explorer 6 Bugs
            .. in addition the author recommends always using !DOCTYPE, and makes a good case.
            .. other good tips, ie: the CSS Reset Rule.
            have a read y'all !
            I'm not here much anymore.
            • chrisglasierC
              chrisglasier
              @newone said:
              How can I hide scrollbars in webdialog?
              css ...
              body{
              border;0px;
              margin;0px;
              overflow;hidden   }
              • Dan RathbunD
                Dan Rathbun
                CSS Attribute overflow:
                With Internet Explorer 6 and later, when you use the !DOCTYPE declaration to specify standards-compliant mode, this property (overflow ) applies to the html object.
                1. MSDN Library / CSS Reference: overflow Attribute | overflow Property
                  MartinRinehart
                  @dan rathbun said:
                  NewOne, and all ... I found this article ... very informative
                  Thanks, Dan.
                  So informative, in fact, that it would be nice if you posted a new topic re IE6 Cheat Sheet, or something similar so Google will find it for us.
                  • chrisglasierC
                    chrisglasier
                    @chrisglasier said:
                    > css ...
                    > body{
                    > border;0px;
                    > margin;0px;
                    > overflow;hidden   }
                    Sorry forgot the pic
                    • N
                      NewOne
                      @chrisglasier said:
                      > css ...
                      > body{
                      > border;0px;
                      > margin;0px;
                      > overflow;hidden   }
                      But you don't use !DOCTYPE, right? πŸ’š Paste this on the top of your Html page and tell me if overflow works for you. Also your window border...
                      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
                      • chrisglasierC
                        chrisglasier
                        My top:
                        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
                        <html>
                        <!-- Copyright 2007-9 Chris Glasier -->
                        <!--This follows the Nameset format for easy integration-->
                        <head>
                        <title>Scene machine</title>
                        <LINK href="Scene machine.css" rel="stylesheet" type="text/css">
                        <script type = "text/javascript" src = "javascript/sceneDevice.js"></script>
                        </head>
                        Body css in external file of course.
                        • chrisglasierC
                          chrisglasier
                          Adding "http://www.w3.org/TR/html4/loose.dtd" looks like this:
                          but the webdialog is on the local drive so I don't see the big deal. But please let me know if there is one!
                          • N
                            NewOne
                            [attachment=0:1ma73d3a]<!-- ia0 -->cgScenes no scroll 002.png<!-- ia0 -->[/attachment:1ma73d3a]
                            Same thing happens to me. So, I used your version of !DOCTYPE πŸ’š
                              Jim
                              Is there a single, simple answer to this?
                              • N
                                NewOne
                                Well, I use <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> and <body scroll="no">. This seems to be working in all the cases. Other suggestions are not working if I use !DOCTYPE.
                                I think this is the universal answer.
                                  I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
                                  • chrisglasierC
                                    chrisglasier
                                    Don't you think in good time such application may well need web connectivity, say, to get or set remote data? Making things comply with today's standards could save future hassles for following generations.
                                      I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
                                      It's not something that will cause problems for future plugins - if future SU corrects the bug, then this little attribute don't do much.
                                      • chrisglasierC
                                        chrisglasier
                                        Ok no big deal except I am working on the API webdialog (which will include snippets). It seems there is a conflict between this:
                                        body{
                                        border;0px;
                                        margin;0px;
                                        overflow;hidden   }
                                        and STRICT doctype, so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
                                        It would be useful for me to understand.
                                          I don't know why the overflow with STRICT doctype within a Webdialog doesn't work - it's how you do it with websites.
                                          Seeing that the Webdialog has a scroll property for it's creating of the ruby class I'd expect that the scrollbars should be set from ruby. I think that the embedded IE control has a scroll property which developers who wish to embed HTML content can set to a fixed override. Why this argument isn't adhered to, I don't know.
                                          I wonder if the SU dev team has been made aware of the scrollnar bug.
                                          Was it so that this is PC only - that it works as expected on Mac?
                                          • chrisglasierC
                                            chrisglasier
                                            Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
