    WebDialog help - hide scrollbars
    31 Posts 7 Posters 7.3k Views 7 Watching
    • chrisglasierC Offline
      chrisglasier
      @newone said:
      But you don't use !DOCTYPE, right? πŸ’š Paste this on the top of your Html page and tell me if overflow works for you. Also your window border...
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
      My top:
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
      <html>
      <!-- Copyright 2007-9 Chris Glasier -->
      <!--This follows the Nameset format for easy integration-->
      <head>
      <title>Scene machine</title>
      <LINK href="Scene machine.css" rel="stylesheet" type="text/css">
      <script type = "text/javascript" src = "javascript/sceneDevice.js"></script>
      </head>
      Body css in external file of course.
        chrisglasier
        Adding "http://www.w3.org/TR/html4/loose.dtd" looks like this:
        but the webdialog is on the local drive so I don't see the big deal. But please let me know if there is one!
        • N Offline
          NewOne
          [attachment=0:1ma73d3a]<!-- ia0 -->cgScenes no scroll 002.png<!-- ia0 -->[/attachment:1ma73d3a]
          Same thing happens to me. So, I used your version of !DOCTYPE πŸ’š
            Jim
            Is there a single, simple answer to this?
            • N Offline
              NewOne
              Well, I use <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> and <body scroll="no">. This seems to be working in all the cases. Other suggestions are not working if I use !DOCTYPE.
              I think this is the universal answer.
                I use STRICT doctype and <body scroll="no">. Since this is for an application I don't care that it's not standard.
                  chrisglasier
                  Don't you think in good time such application may well need web connectivity, say, to get or set remote data? Making things comply with today's standards could save future hassles for following generations.
                    I'm a strong proponent of webstandards. But I'm also pragmatic - this is to work around an SU bug where the scrollbar argument in SU's Webdialog class doesn't take effect.
                    It's not something that will cause problems for future plugins - if future SU corrects the bug, then this little attribute don't do much.
                      chrisglasier
                      Ok no big deal except I am working on the API webdialog (which will include snippets). It seems there is a conflict between this:
                      body{
                      border;0px;
                      margin;0px;
                      overflow;hidden   }
                      and STRICT doctype, so shouldn't the solution be within HTML compliance and standards and not within Sketchup webdialogs?
                      It would be useful for me to understand.
                        I don't know why the overflow with STRICT doctype within a Webdialog doesn't work - it's how you do it with websites.
                        Seeing that the Webdialog has a scroll property for it's creating of the ruby class I'd expect that the scrollbars should be set from ruby. I think that the embedded IE control has a scroll property which developers who wish to embed HTML content can set to a fixed override. Why this argument isn't adhered to, I don't know.
                        I wonder if the SU dev team has been made aware of the scrollnar bug.
                        Was it so that this is PC only - that it works as expected on Mac?
                          chrisglasier
                          Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
                            It's make the standard conformant me twitch. x_X
                              Ah!
                              There is a standard conformant way!
                              html
                                overflow; hidden;
                              When removing scoll="no" and adding that to the CSS the scrollbars disappeared in STRICT mode.
                              Armed with that, you could sub-class the Webdialog class and tap into it's .new method and pass on the scroll argument to the webdialog when it's ready. Unless you're fine with just having it defined in the CSS and ignore the Ruby argument.
                              I was going to make a wrapper for myself, that took care of the matter where the size is only being read the first time it's created. At the moment, if you try to change the size arguments for a non-resizable webdialog they won't take effect unless you purge the saved settings.
                                chrisglasier
                                Good and noted! And used here.
                                  I don't know why I didn't try that before. I know that when switching between STRICT and quicks the behaviour of HTML and BODY changes.
                                  Glad we finally worked it out.
                                    @newone said:
                                    One more thing: JS statement element.selected = true; did not worked on my native SU instalation. After I updated my Internet Explorer from 6 to 7, it did worked... how is this possible, because in SU I still have IE4 ?
                                    You don't have IE4 in SU. You have whatever is installed on the system.
                                    That's one of the reason I would prefer is SU used a standalone web-frame that isn't linked to the system.
                                    • N Offline
                                      NewOne
                                      Please run this.
                                      @my_dialog = UI;;WebDialog.new('Check Version', false,"",400, 100, 300, 300, true)
                                      html = '<html>
                                      <body>
                                      <script type="text/javascript">
                                      var browser=navigator.appName;
                                      var b_version=navigator.appVersion;
                                      var version=parseFloat(b_version);
                                      document.write("Browser name; "+ browser);
                                      document.write("<br />");
                                      document.write("Browser version; "+ version);
                                      </script>
                                      </body>
                                      </html>'
                                      @my_dialog.set_html(html)
                                      @my_dialog.show{}
                                      @my_dialog.bring_to_front
                                        You can't rely on navigator.appVersion. Since IE4 and up it has always reported 4 for legacy support reasons. You must parse the navigator.userAgent string.
                                        http://javascript.gakaa.com/navigator-appversion.aspx
                                        JavaScript - Browser detect
                                        (www.quirksmode.org)
                                        • N Offline
                                          NewOne
                                          If so, why does it renders buttons so old-way? 😞
                                            IE is quick to do weird stuff to form control. In general - form controls in any browser is unpredictable.
                                            If it'd been rendering like IE4 it would be permanently stuck in Quicks mode. Standard mode in IE wasn't introduced until IE6.
