    Determine zoom level through API
    5 Posts 3 Posters 412 Views 3 Watching
      timc
      Is there a way to determine the zoom level through the Sketchup API?
      I am trying to emulate the way the circle drawing tool displays a circle around the current mouse position. I can display a circle with ease, but the circle gets larger as I zoom in. I want the circle to remain the same size despite how far I zoom in or out.
      Any help would be appreciated, Thanks.
        You drawing stuff on the viewport from a Tool? Or are you drawing geometry?
        For drawing 2D stuff on the viewport you can use view.pixels_to_model http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pixels_to_model
          Why zoom level ? This method draws a fixed size circle ??
          def draw(view)
            ###make the circle data here, as an array of points, and them in view.draw_polyline(points) to make the circle...
          end#def
            timc
            This is the code I'm using
            #This is what I have in the draw method of my tool
            def draw(view)
            	#@temp = the current mouse location. it is set in the mousemove method.
            	@normal = view.camera.direction
            	@pts_circle = circle_points(@temp.position, @normal, 10, 24)
            	view.drawing_color = "blue"
            	view.draw_polyline(@pts_circle)
            #This is a function I found that creates the points needed to draw a circle
            def circle_points(center, normal, radius, numseg)
            	# Get the x and y axes
            	axes = Geom;;Vector3d.new(normal).axes
            	xaxis = axes[0]
            	yaxis = axes[1]
            	zaxis = axes[2]
            	xaxis.length = radius
            	yaxis.length = radius
            	# compute the points
            	da = (Math;;PI * 2) / numseg
            	pts = []
            	for i in 0..numseg do
            		angle = i * da
            		cosa = Math.cos(angle)
            		sina = Math.sin(angle)
            		vec = Geom;;Vector3d.linear_combination(cosa, xaxis, sina, yaxis)
            		pts.push(center + vec)
            	# close the circle
            	pts.push(pts[0].clone)
            	pts
            If I use the mouse wheel to zoom while the tool is active the circle stays at a diameter of 10, so it appears larger if I zoom in and smaller if I zoom out.
              timc
              Thank you thomthom, that is exactly what I was looking for.
