    SU 7.1 - Dimension problem
    3 Posts 3 Posters 720 Views 3 Watching
      agrazdi
      Any body has the same problem with the new 7.1 update ?
      agrazdi
      • N Offline
        NewOne
        It's worse than that... I moved the plane off origin or axes and as you can see, the dimension snaps on origin. πŸŽ‰
        Hope it will be resolved.
        • cmdC Offline
          cmd
          This is a known issue that we are planning on fixing in the next maintenance release.
          The issue will occur when adding text and dimensions at true intersections.
          The workarounds:
          Option 1) Draw two intersecting lines at the point of intersection, add the text and then delete the lines.
          Option 2) You can use LayOut's new dimensioning tool to create the needed dimensions. You should not get the odd behavior while in LayOut.
          Cheers,
          CMD
          • CMD
