    Object disappear from layout (7.1)
    layout
    3 Posts 2 Posters 1.1k Views 2 Watching
    • dcauldwellD Offline
      dcauldwell
      Using the new version (7.1), pipes (cylinders) on plan, which showed up in the previous version, now disappear in the latest version.
      Am I missing a setting somewhere?
      This image is from the SU model - the pipes simply disappear in Layout
      http://img200.imageshack.us/img200/8231/5129bldgregs.jpg
      Sketchup 2017
      (vray 2.00)
      • Tyler MillerT Offline
        Tyler Miller
        Hi dcauldwell -
        I think you are seeing the effects of a design decision we had to make while overhauling the SketchUp rendering engine. Previously, even if your SketchUp style did not have edge profiles on, we would still draw the edge when a softened edge was in profile. The new engine strictly adheres to what the style is set to. So, if you don't have profiles on, then it will not draw cylinder profiles. To get back to the old look, just turn profiles on in your style.
        Hope that helps,
        Tyler
        Google
          dcauldwell
          Tyler
          Thanks for the response.
          David
          Sketchup 2017
          (vray 2.00)
