    Displacement maps from Fog
    7 Posts 6 Posters 2.5k Views 6 Watching
    • J
      jopsa2
      I apologise for the size of the images, I had to scale the image down to fit forum rules. Hopefully you'll get the gist of it without the larger images.
      I'm sure this isn't groundbreaking, it's just a method for creating displacement maps using the fog in Sketchup. Surely I'm not the first one to think it up, but I felt quite proud seeing the decent results it produced.
      http://forums.sketchucation.com/download/file.php?mode=view&id=33478&sid=10b6309c6dd4389f7c995fa9ca5be2ed
      • EscapeArtistE
        EscapeArtist
        That's really neat. What software are you using the displacement in?
        • A
          Aerilius
          Thanks! This is very helpful for me and much faster than making a depth render in KT.
          • J
            jopsa2
            Cheers guys! EscapeArtist, I'm using VRay to render it.
            I'm sure my technique with the fog can be refined, I was basically aiming to get as much contrast in Sketchup as possible.
            Also, I was telling a friend today about it, and he pointed out that displacement maps are basically hypsometric plans! (hypsometric plans are used in topography, they are colour-coded according to height)
            So now I'm printing out my displacement map because I can use it as a hypsometric ๐Ÿ˜„ very proud lol
            • E
              Ecuadorian
              Actually this technique can also be used to produce bump maps from geometry, very cool!
              -Miguel Lescano
              • M
                mirjman
                how are you controlling the height of the displacement so that it matches real world units?
                • J
                  jopsa2
                  I'm not... ๐Ÿ˜• ๐Ÿ˜† I just eyeballed it, did a couple of tests before settling... I did think about it, and I guess a more precise way of eyeballing it (so not precise either) would be opening both files, use the front view on both and compare.
                  I remember reading somewhere the multiplier for displacement maps had some real world meaning, I'll do some research.
