    Trees, dwg and component
    2 Posts 2 Posters 545 Views 2 Watching
    • D
      donaldaugustsson
      How is this possible?
      http://www.youtube.com/watch?v=O5pu2qHoX-s#t=0m25s
      What kind of "information"/object must the tree have in the dwg-file, to make this possible...because it doesnt work with "normal" lines? ...why i ask is that it doesnt work with my imported dwg-file
      I might psot the skpfile here...but its a really large file...soo...anyway, any information is helpful
      Thanks for the help
      • E
        Ecuadorian
        In AutoCAD, make sure your trees are "blocks". You should be able to edit one tree in ACAD and see all others change at once. Then, when you import to SketchUp, those blocks become components. If you double-click on a SketchUp component you can add something inside and that object will appear in all instances of the same component. This is what he did.
        -Miguel Lescano
