    Question about painting model
    11 Posts 6 Posters 844 Views 6 Watching
    • P Offline
      piki
      hi:)
      i am new to this lovely tool (sketchup) and i would like to know if there is option to paint specific pixel on model lets say with brash or pencil, cause the bucket fill's big ereas.
      if not, can i import the model into paint software?
      thanks.
        remus
        That isnt possible in SU. I've got a feeling you can do it in blender, although ive got no idea how 😛
        To get your SU modl to blender: go file->export then export as .kmz. Then change .kmz to .zip, unzip it and te .dae bit can be opened in blender.
          johnsenior1973
          You can paint on the individual faces with an external painting application of your choice, eg Photoshop, Artweaver, Paint.net etc.
          To do that you right click on the face > Make Unique Texture. Then right click on the face again > Texture > Edit texure Image. I think the first time you do this you will then be given the choice of choosing which Image Editing app you want to use. When you've finished in the painting app, simply save the image and the changes will be made in SU.
          You can also set the Image App SU uses, or change it in future, by going to Windows > Preferences > Applications.
          • P Offline
            piki
            hi remus , looks like we both learn something;)
            thanks johnsenior1973, works perfect 😄
            • E Offline
              Ecuadorian
              Thank you, johnsenior1973. This trick will come in handy 👍
              -Miguel Lescano
                Hi guys,
                John has some point here. In SU7, the texturing tool (more exactly how you can interact with textures) has been greatly improved and though we do not have better UV mapping tools, there are a lot of things you can do with already mapped textures.
                This is really worth a better look IMO.
                • numbthumbN Offline
                  numbthumb
                  Thanks for the explanation. Another question if you guys don´t mind. What do I have to do if I want to edit a texture applied on a surface? ( i.e. not on a single face?)
                  Comfortably numb...
                    johnsenior1973
                    I'd create a flat face the same size as the surface you want painting. I'd then paint that face using the technique above. Then right click on that texture and click on Texture > Projected.
                    Then sample that paint texture and paint it on your curved surface.
                    http://img215.imageshack.us/img215/4752/projectedtexture.th.jpg
                      numbthumb
                      DOH!
                      Comfortably numb...
                        OR instead of projecting it, wrap it around (remember the other topic).
                        It all depends on the "project".
                          numbthumb
                          Doh! again. Slight memory disturbances in the aged, I guess...
                          Comfortably numb...
