    Right click menu disabled???
    26 Posts 11 Posters 6.6k Views 11 Watching
    • P
      prismcnd
      sorry been away on a project, i'm running sp3 as well
      “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
      • halroachH
        halroach
        Hi EarthMover,
        I am unfamiliar with the different toolbars you are using and am curios what they are:
        1. the second column from the left - I recognize Vray and Twilight render. what are the others below them?
        2. the bottom most toolbars?
        3. 2D tools!? searched from them and couldn't fine them...
        I remember seeing a thread with a ruby script toolbar pictures? anyone remember something like that?
        Sorry I can't help with your problem 😄 good luck with that!
        Thanks!
        http://forums.sketchucation.com/download/file.php?id=33044&mode=view
        FlexTools - Super Quick Windows, Doors, Slats...
        • O
          orei
          i've the same worth problem.. those are the ruby plugin script that i've installed in my plugin su folder:
          http://img8.imageshack.us/img8/4694/rubyscript.th.jpg
          plugin script
          • EarthMoverE
            EarthMover
            Anyone happen to get to the bottom of this? I was hoping the update to 7.1 would fix it, but to no avail. I have been using sketchup like this for months now. In order to get to the contextual menu I have to access it through the bottom of the Edit menu and all of these work....however I still lose all right click functionality shortly after starting on a new session. Hard to discover the culprit, because it doesn't happen right away. I'd have to go through 200 scripts one at a time and then use SU for 5-10 minutes to see if it is the issue. Would take forever. Hoping someone happened to stumble on to a cure. (Fingers crossed)
            Content Creator at Skapeup
            • R
              remus
              The last i heard, it had been found that right clicking the same face lots of times (10-20) consecutively will bring up this bug, havent heard about a solution yet, though.
              • thomthomT
                Got a screenshot list of your plugins folder?
                • 2 / 2
