    Lighting with Sketchy Edges
    11 Posts 4 Posters 1.8k Views 4 Watching
    • Al HartA
      Al Hart
      I am experimenting with superimposing Sketchy edges on rendered images.
      Here is a Sketchy Edge interior in SketchUp.
      (3D Warehouse model: A CONTEMPORARY ATTIC BY ASTRID ALEJANDRA ROMERO PULIDO)
      Here is the same model rendered with lighting, but no edges.
      Here is a 50-50 blend of the two images.
      This combines the Sketchy edges with the shadows.
      Does this seem like it would be a useful effect?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • olisheaO
        olishea
        looks cool al, i love line-overs like this.
        But I would set your blending mode to 'multiply' for the lines so that all the white disappears. Then reduce opacity to around 50%.
        Its a shame you have lost the detail in the render, unless that was your intention. It would be nice to have the detail and the bold lines together.
        oli
        • olisheaO
          olishea
          sorry like this. I hope you dont mind.
          Blending mode=Multiply. Line Layer opacity= 100%
          http://i654.photobucket.com/albums/uu269/olishea/attic_edit.jpg
          Line Layer opacity 50%
          http://i654.photobucket.com/albums/uu269/olishea/attic_edit_50.jpg
          Line layer opacity 60% with colorized render layer.
          http://i654.photobucket.com/albums/uu269/olishea/attic_edit_50_orange.jpg
          what do you think?
          oli
          • Al HartA
            Al Hart
            Thanks olishea,
            I'll work harder to keep the detail. I thought I had the white in the line image set to transparent, but I must have missed something.
            Does the "multiply" effect in Photoshop set the transparency to match the darkness of the overlaid image?
            Or does "multiply" retain the darkest of the two images?
            (I am trying to do this directly from SketchUp - by blending images myself - without using Photoshop)
            Al Hart
            • Al HartA
              Al Hart
              Multiple in Photoshop
              Looks at the color information in each channel and multiplies the base color by the blend color. The result color is always a darker color. Multiplying any color with black produces black. Multiplying any color with white leaves the color unchanged. When you’re painting with a color other than black or white, successive strokes with a painting tool produce progressively darker colors. The effect is similar to drawing on the image with multiple magic markers.
              I'll look harder and see how they do it...
              [Edit]
              I found this equation. I'll give it a try...
              http://www.binary-artist.com/photoshop_tutorials/images/multiply_formula.gif
              Apparently they just "multiply" the RGB values individually.
              Al Hart
              • olisheaO
                olishea
                its easy al.
                with multiply.......all the white turns transparent
                with screen.....all the black turns transparent.
                If you ever wanna get rid of the white without masking/erasing etc just multiply. its a single click operation although yes you gotta use photoshop.
                it sounds like a load of photshop mumbo jumbo that quote (just like the manual lol), just give it a go!!
                oli
                • tbdT
                  tbd
                  I think you need to have only the edge on 50% like this:
                  (base * edge * 0.5) / 255
                  SketchUp Ruby Consultant | Podium 1.x developer
                  http://plugins.ro
                  • Al HartA
                    Al Hart
                    Thanks TBD.
                    I wound up using
                    (base * (255 - (255-edge) * opacity))/255
                    Otherwise the 0.5 would make the image too dark for the white of the edges.
                    Al Hart
                    • Al HartA
                      Al Hart
                      The equation I found works pretty well at 100% opacity of the edge lines.
                      I'll have to think a little about how to apply it to the 50-50 blend.
                      [Edit]
                      I think I got the 50% version to work properly as well.
                      Al Hart
                      • tbdT
                        tbd
                        you can implement more modes - check out photoshop blend modes explained
                        http://plugins.ro
                          I like it. I've done something similar to that.
