    Req: woodwork.rb
    6 Posts 4 Posters 1.4k Views 4 Watching
    • D
      dedmin
      Hi, ruby masters!
      I'm using this wonderful plugin woodwork.rb http://forums.sketchucation.com/download/file.php?id=22441
      Is there a way to use simple expressions in the dialog boxes and to make a drop down list of most used component names? This script is a huge time saver when working with melamine faced sheeds and any kind of plywood. I already asked the author but he seems is not around for a while.
      Thanks in advance.
      • M
        MartinRinehart
        Do you have a link to any explanatory material? What does this do? Who wrote it? The one you posted is to the code. When I tried it, drill and dado appeared inoperative, probably because I didn't know how to use them.
        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        • massimoM
          massimo Moderator
          Never tried this plugin, but maybe a look at this will help you.
          • D
            dedmin
            Dado and drill work on components - when you choose one of them look at the bottom for tool tips.
            It is working wonderfully for me and a little bit of improving would be great - to use simple expressions when making shelves, drop down menu with all the names like top, bottom, back and etc.
            http://www.youtube.com/watch?v=cdHQ-FB4WAo
            • J
              jhoutman
              Hello,
              I am the author. I am sorry I rarely stop by this forum. I changed email address so probably everything got lost. Let me know what changes you like and I will probably do them. My main hobby is woodworking. A sub hobby is Sketchup. A sub-sub hobby is ruby scripts. I do have small word documents describing the the use of the tools. And have some updates.
              Joel
              • D
                dedmin
                @jhoutman said:
                Hello,
                Joel
                Hello,jhoutman
                I'm glad to see you back! And thanks for this very helpful plugin! When making boards - say shelf, it would be very handy to use simple expressions - width of the cabinet minus double thickness of the plywood. Also, a drop down list with most used names for the parts - top, bottom, back etc. in the "Input Board" window. Thanks in advance.
