    3d cubes with Great mirror effect
    5 Posts 5 Posters 657 Views 5 Watching
      rmartin
      How can i obtain an effect like this
      http://www.istockphoto.com/file_thumbview_approve/2073118/2/istockphoto_2073118-blue-and-one-red-3d-blocks.jpg
      How i can to obtain a white floor with a mirror effect?
      thanks
      rmartin
        Not by SU itself. You'd have to use a render engine.
          remus
          podium and twilight would be good render engines to look at, theyre both fairly easy to get the hang of.
          podium: http://www.suplugins.com/
          twilight: http://twilightrender.com/
            andre51
            You could also try Kerkythea..... it's free!
            • E Offline
              elis
              In attach a simple jpg: a white floor with a mirror effect using only SketchUp.
              A good tutorial:
              http://forums.sketchucation.com/viewtopic.php?f=22&t=4721
              or wonderful examples:
              http://forums.sketchucation.com/viewtopic.php?f=81&t=17265&st=0&sk=t&sd=a&start=15
              For other effects you must use a rendering software as explained in the previous reply posts.
              Eli
