    Assigning Event Handlers in JS-Written UI, Painlessly
    9 Posts 2 Posters 1.4k Views 2 Watching
    • M
      MartinRinehart
      If your WebDialog's UI is a function of the model's content, you will need to use JavaScript to create the UI. This is easy if you follow this model.
      <!-- a.html -->
      <html> <body onload=init()>
      <script>
          var giggle = function() { alert('That tickles!') }
          function init() {
          	var btn = document.createElement( 'button' );
          	btn.innerHTML = 'Click Me!';
          	document.body.appendChild( btn );
          	btn.onclick = giggle;
      </script>
      </body> </html>
      You can't document.write() your UI and you can't assign event handlers before you attach the listeners to the DOM. Your script, or your link to a .js file, should be the last thing before </body> (never in the <head> section).
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • thomthomT
        I always keep the links to JS in the HEAD. I attach an init function to the DOMContentLoaded event (it's triggered immediately after the HTML is loaded - but doesn't wait for all images and other resources like onLoad does.) and that works fine. Standard web-design practice.
        • M
          MartinRinehart
          That risks being bitten by The Bug from Hell, which you definitely don't want. Also, see http://www.amazon.com/High-Performance-Web-Sites-Essential/dp/0596529309 . Formerly Yahoo's front-end guru, Souder is now with Google.
          • thomthomT
            "The Bug from Hell"?
            • M
              MartinRinehart
              http://21st-century-languages.blogspot.com/2009/08/bug-from-hell.html
              • M
                MartinRinehart
                In my example code, I attach an anonymous function to a variable;
                var foo = function() {...}
                Later, this function is attached to the "onclick" method:
                btn.onclick = foo
                Suppose you have several buttons. You might want to pass a button number as an argument. How?
                Use the button's id. Example:
                    var which_one = this.id;
                Suppose you really, truly want a number:
                button.id = number + '_btn';
                    var which_one = parseInt( this.id );
                • thomthomT
                  Will the browsers accept that ID you give the element? The specs says that and ID attribute must begin with a letter. (Not sure how the browsers deal with this when they encounter it. Ignore it - or accept it?)
                  I'm pondering about the cache problems you have. By the sound of it we used the same method - in locating the script in the HTML. But experience different results. I'll see if I can get a developer demo of my script uploaded for comparison.
                  • thomthomT
                    What version of IE do you deal with? I think most my machine now have IE8 - not sure if I ran that plugin under IE7...
                    • M
                      MartinRinehart
                      Hmmm. Yes for IE 8.
