    Assigning Event Handlers in JS-Written UI, Painlessly
    9 Posts 2 Posters 1.1k Views 2 Watching
      MartinRinehart
      If your WebDialog's UI is a function of the model's content, you will need to use JavaScript to create the UI. This is easy if you follow this model.
      <!-- a.html -->
      <html> <body onload=init()>
      <script>
          var giggle = function() { alert('That tickles!') }
          function init() {
          	var btn = document.createElement( 'button' );
          	btn.innerHTML = 'Click Me!';
          	document.body.appendChild( btn );
          	btn.onclick = giggle;
      </script>
      </body> </html>
      You can't document.write() your UI and you can't assign event handlers before you attach the listeners to the DOM. Your script, or your link to a .js file, should be the last thing before </body> (never in the <head> section).
        I always keep the links to JS in the HEAD. I attach an init function to the DOMContentLoaded event (it's triggered immediately after the HTML is loaded - but doesn't wait for all images and other resources like onLoad does.) and that works fine. Standard web-design practice.
          MartinRinehart
          That risks being bitten by The Bug from Hell, which you definitely don't want. Also, see http://www.amazon.com/High-Performance-Web-Sites-Essential/dp/0596529309 . Formerly Yahoo's front-end guru, Souder is now with Google.
            "The Bug from Hell"?
              MartinRinehart
              The Bug from Hell
              Executive Summary One full week lost. Zero output units. It was the bug from hell. If you have any faith in your software schedules, read on...
              (21st-century-languages.blogspot.com)
                MartinRinehart
                In my example code, I attach an anonymous function to a variable;
                var foo = function() {...}
                Later, this function is attached to the "onclick" method:
                btn.onclick = foo
                Suppose you have several buttons. You might want to pass a button number as an argument. How?
                Use the button's id. Example:
                    var which_one = this.id;
                Suppose you really, truly want a number:
                button.id = number + '_btn';
                    var which_one = parseInt( this.id );
                  Will the browsers accept that ID you give the element? The specs says that and ID attribute must begin with a letter. (Not sure how the browsers deal with this when they encounter it. Ignore it - or accept it?)
                  I'm pondering about the cache problems you have. By the sound of it we used the same method - in locating the script in the HTML. But experience different results. I'll see if I can get a developer demo of my script uploaded for comparison.
                    What version of IE do you deal with? I think most my machine now have IE8 - not sure if I ran that plugin under IE7...
                      MartinRinehart
                      Hmmm. Yes for IE 8.
