    Help
    20 Posts 3 Posters 1.8k Views 3 Watching
    • W
      Windknot
      I am having a hard time getting a measurement for the spacing of my 2x2's on the top of the main beams.
      Is there a trick to getting the ruler to work on curves?
      • GaieusG
        Turn on hidden geometry in the View menu and the "revealed", hidden lines should let you snap dimensions and all work fine.
        • M
          mhtaylor
          You don't have to use the tape measure - if you select all the lines that make up the curve and look in the "Entity Info" window it will display the total length - in the case of your model I read it as 14' 9 1/16"
          The Other Martin Taylor aka: The SketchUp Fanboy
          • W
            Windknot
            I understand that, but am still confused as how to place the 2x2's. Sorry about all this, first time dealing with technical curves.
            • GaieusG
              It seems that the two of us replying your (first) post understood your problem totally differently.
              Please, can you tell what exactly do you want to snap to the geometry (or at lest that either of our answer was somewhat close to your problem?)
              • M
                mhtaylor
                This tutorial is what you are trying to do I think: http://blogs.taunton.com/n/blogs/blog.aspx?nav=main&webtag=fw-designforum&entry=92
                Basically you use the weld plugin to create a complete path along which you can then copy your 2x2s.
                • W
                  Windknot
                  I am about to give up trying to space these out evenly. I have had all kinds of trouble getting them correct.
                  • GaieusG
                    When you've already welded the path (have you?) use pathcopy.rb plugin to distribute those parts evenly along this curved path:
                    http://www.smustard.com/script/PathCopy
                    If you haven't used plugins yet, see the Smustard FAQ what (and how) to do with a ruby plugin like this.
                    http://www.smustard.com/faq/
                    • W
                      Windknot
                      Thanks man, I have run both scripts, my calculations are off on the spacing. I need to go do some more figuring on the calculator.
                      • M
                        mhtaylor
                        The tutorial and plugins seem to work ok - here is your model with the slats 4" apart (enter 6" in spacing plugin to take account of the slat width too.
                        • W
                          Windknot
                          @mhtaylor said:
                          [attachment=0:36ygkkwt]<!-- ia0 -->pergola.jpg<!-- ia0 -->[/attachment:36ygkkwt]
                          Wow, looks great. My only complain is that one 2x2 is flush on one side and the other is a couple inches off of being flush. It there anyway to get around this without making a new path taking in account where I want them to start?
                          • M
                            mhtaylor
                            @windknot said:
                            @mhtaylor said:
                            [attachment=0:2pmhv1mb]<!-- ia0 -->pergola.jpg<!-- ia0 -->[/attachment:2pmhv1mb]
                            If you let me know how many slats you want placed between one end and the other I can give you specific instructions and update your model for you.
                            Regards - Martin
                            • W
                              Windknot
                              @mhtaylor said:
                              @windknot said:
                              @mhtaylor said:
                              [attachment=0:1eklkc6h]<!-- ia0 -->pergola.jpg<!-- ia0 -->[/attachment:1eklkc6h]
                              Regards - Martin
                              Martin, I want the slats to be 3"x3" and I want them 16" on center but want them to end the same distance from the end on both sides. Thanks for all of the help!
                              • M
                                mhtaylor
                                @windknot said:
                                @mhtaylor said:
                                @windknot said:
                                @mhtaylor said:
                                [attachment=1:3qwazk5h]<!-- ia1 -->pergola.jpg<!-- ia1 -->[/attachment:3qwazk5h]
                                Regards - Martin
                                I hope the attached is what you are looking for.
                                Pergola with slats in place
                                • W
                                  Windknot
                                  Martin, thanks for all your help. I will give you credit with help on the design.
                                  • M
                                    mhtaylor
                                    @windknot said:
                                    A couple of questions, please see attached image. (I am sorry for the huge file size, re-sized down, you really lose what I am talking about)
                                    http://i182.photobucket.com/albums/x178/CCG_TX/help-pergola.png
                                    I think you're going to have to create a new path for the pieces going on the top of the previous slats - the curve of that path will have to either incorporate the flat edge of the top of the slat or carefully touch the highest point of the slat with clear line of site to the next slat - or you could just cut a notch in the new curved pieces πŸ˜„
                                    • W
                                      Windknot
                                      Is there a script out that that will allow me to create a new path without having to use the line and arc tool?
                                      • W
                                        Windknot
                                        Thanks for the help, but I still can't get it to snap following the curve of the beam.
                                        • W
                                          Windknot
                                          That's it! Thanks!
                                          • W
                                            Windknot
