    Question (request :-)
    8 Posts 4 Posters 615 Views 4 Watching
      tomsdesk
      Is there a selection tool similar to autocad's "window/crossing polygon" or at least the "fence" selection tool?
      Haven't found one (though I've never had much luck finding what I'm looking for) but would be especially great if there was! Thanks in advance for your help, Tom.
      2.5D Trees & Shrubs!
      • Chris FullmerC Offline
        I use autocad, but I'm unfamiliar with what you mean I think. I thought that was just the typical cad right to left will select only entities that are entirely within the selection window, while left to right will select any objec the selection window touches. What would the selection fence be beyond that?
        Chris
        All my Plugins I've written
          markozeta
          This may actually a display issue, that I had, where the selection tool will not create the bounding box.
          Try turning off hardware acceleration (Window -> Preferences -> Hardware Acceleration).
          See if that helps.
          Mark
          BSME - Cal Poly Pomona
          Sketchup Pipe Maniac
            tomsdesk
            The standard autocad selection is indeed a rectangle...but you can qualify that selection with "crossing or window polygon" to select multiple corners for an irregular selection shape: thus the ability to select only the desired entities along a diagonal (or a u-shape or whatever). "Fence" is another qualifier that uses a poly-like line (in any direction and number of vertices) as a crossing selection entity.
            Wouldn't such be quite useful in SU? Is it possible?
              tomsdesk
              Bump...?
                tomsdesk
                Shall I take it this is impossible in SU?
                  Nothing is 'impossible'... BUT something are just so hard we'll ignore them till they bite us in the butt !
                    tomsdesk
                    @tig said:
                    ...till they bite us in the butt...
                    So you do understand the timing of my question :`)
