    Landscape Plant Packs - 68 total (update w. alphas)
    68 Posts 49 Posters 67.0k Views 49 Watching
    • F
      fbo_bern
      Hi all
      The collection is great!!
      But if i want to render the plants, that looks bad:
      What is the problem? Options? Or are the plants not make for rendering?
      i use vray for sketchup.
      thanks for help and tips.
      fbo
      • A
        alpro
        fbo_bern, you need to load the alpha in the transparency slot of the diffuse material for it to render in Vray, at least till the new version is out.
        Mike
        • O
          Ondreas
          I`ve been out for some time but what I have found here when I came back is just fantastic !!!
          For example this 2D Landscape Plant Pack created by EarthMover with addition from Adam.
          Very well done, guys !!! πŸ‘ πŸ‘ πŸ‘
          Thank you very, very much EarthMover & Adam for sharing these great 2D plants...
          One of the best collection I have come across so far !!!
          Thanx again !!!
          • W
            wahoowetzel
            Equadorian,
            Are these renderings or image exports from sketchup? I ask because when I try to use them in sketchup I get a square shadow. These work great for renderings, but I'm making an AVI from sketchup and I'd like to have tree shaped shadows, not this:tree test.png
            FYI, I'm still in the process of replacing my place holders, so nevermind the lampshades πŸ˜‰
            • GaieusG
              Hi Jesse,
              The problem with SU is that although it recognises alpha transparency, its shadows do not support it. So the general workaround is either to roughly cut around the tree shape of turn its shadows off and use a generic, shadow casting face with a transparent image applied on it.
              • K
                KXI System
                I got rapidshare to work, now I have and and LOVE IT! 😍
                I really can see myself using these in the future, but one question...
                Why is there logs on fire in the collection?
                Getting the perfect sig is hard...
                Google it!
                • S
                  SHAHEEN
                  thanks for these great images .. they will be useful
                  wahoowetzel : u can get rid of this annoying shadow by applying the tree as a material on a plane
                  edit the material to add the tree then add the alpha image to the transparency ... that how u can get areal shadow . see the attached images .
                  result
                  " An eye for an eye only ends up making the whole world blind "
                  Gandhi
                  • GaieusG
                    Hi Shaheen
                    Each file gives the same "not valid" result.
                    • EarthMoverE
                      EarthMover
                      @ondreas said:
                      Thank you very, very much EarthMover & Adamfor sharing these great 2D plants...
                      Thanx again !!!
                      You're welcome and you're welcome! πŸ˜„
                      Shaheen,
                      Better yet, the new update of Vray supports transparency from the image itself with no alpha map needed for .png or .tif. The days of making clipmaps are gone forever....I hope!
                      .....and THANKS for sharing the new packs!
                      Content Creator at Skapeup
                      • S
                        SHAHEEN
                        and here is my collection for such images ... i uploaded them at 4shared
                        i hope u would like them
                        Pine trees, Palm trees , deciduous trees 1 +2 & 3
                        http://www.4shared.com/file/198841551/42eaa4ef/_Deciduous_Trees_2.html
                        http://www.4shared.com/file/198888642/7846d8c6/_Deciduous_Trees_3.html
                        http://www.4shared.com/file/198807215/f44f4a6b/Deciduous_Trees_1.html
                        http://www.4shared.com/file/198775624/461327ac/others.html
                        http://www.4shared.com/file/198692635/c1b47306/Palm_Trees.html
                        http://www.4shared.com/file/198747085/22df3159/Pine_Trees.html
                        Gandhi
                        • S
                          SHAHEEN
                          😐 sorry Gaieus for that
                          there was an error in coping the lik
                          i have fix them
                          thanks again dude , im glad to be here
                          Gandhi
                          • F
                            fabiorossi
                            thank you so much!!!!!!!!!!!!!!!!!!!!
                            my blog
                            http://progettin3d.blogspot.com/
                            • dermotcollD
                              dermotcoll
                              Thanks Earthmover - they look amazing!
                              When you burn your arse - you gotta sit on the blisters!!
                              • kerabeK
                                kerabe
                                Thanks so much for these! I can't wait to try them out.
                                The CH124: If it isn't leaking, you're out of oil...
                                • J
                                  jeabdc
                                  I love SketchUp, ThankYou
                                  Thailand is Smile Land
                                  • J
                                    jeabdc
                                    Thank for your Plant Collection
                                    • S
                                      SurfingAlien
                                      thank you so much EarthMover!
                                      great billboards collection (and they work great with the "Always Face Camera" option)
                                      as you can see I'm new here, I hope I can give my contribute soon
                                      cheers,
                                      A
                                      • W
                                        whiteninja
                                        thank you so much for all you people who share their beloved plant collections to the community. these really helps πŸ˜† and also thanks for sharing that tip about transparency in vray
                                        • A
                                          alex2402
                                          Hi Adan can you make a tutorial step by step how you make plants like this, and alpha please, i really appreciate your hard work
                                          i wanna create plants like this by my self... thank you in advance ❓ ❓ ❓ ❓
                                          Todos tenemos dones, tu sabes cual es el tuyo?
                                          • C
                                            clucas1975
                                            THANKS EARTH MOVER.
                                            • 3 / 4
