Exploding Using Ruby Script
9 Posts 3 Posters 1.5k Views 3 Watching
    simonstaton
    Basicly I want to explode all the components on the page using a ruby script. I have a
    component inside of a component and the component that is inside the
    main one has attributes so I do not want to explode it completly but
    only explode it once as if I was right clicking then selecting
    explode.
    So far I have made a toolbar that when you press selects everything on
    the page then next I want it to explode this is my code so far.
     toolbar = UI::Toolbar.new "Action 3D Toolbar"
     cmd = UI::Command.new("Explode All") {
     Sketchup.send_action(21101)
     cmd.small_icon = "3dtoolbar.png"
     cmd.large_icon = "3dtoolbar.png"
     cmd.tooltip = "Action 3D Toolbar"
     cmd.status_bar_text = "Testing the toolbars class"
     cmd.menu_text = "Test"
     toolbar = toolbar.add_item cmd
     toolbar.show
    now the only important part here is the Sketchup.send_action(21101)
    and 21101 is the syntax for select all. so all I need to do now is explode as if I am right clicking then selecting explode
    Now is there a syntax for explodeing as I have checked everywhere and
    cant find one maybe somtyhing like this
    Sketchup.send_action “explode:”
      simonstaton
      no ideas?
        tbd
        Sketchup.active_model.selection[0].explode
        you need to add some error testing to see if a component is selected
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          simonstaton
          that still isnt exploding it selects it all. also what do you mean by error testing
            {Sketchup.send_action(21101)} ### scrap it... no need to 'select' anything
            Use this line put inside your {}
            Sketchup.active_model.active_entities).each{|e|e.explode if e.class==Sketchup;;ComponentInstance}
              simonstaton
              that just gave me this error
              C;/Documents and Settings/Administrator/Desktop/action3d/Plugins/Utilities/Toolbar.rb;5; syntax error
                                                         ^Error Loading File LoadToolbar.rb
                simonstaton
                I have just been playing around with the bomb.rb plugin however this does explode it but it explodes it completly and I only want it to explode once. This is the code that explodes all the components complely.
                def bomb_groups
                	model = Sketchup.active_model
                	defs = model.definitions
                	return nil if UI.messagebox("Are You Finished Building Your Climbing Frame This Will Colapse The Model", MB_YESNO) == 7
                	if Sketchup.version[0,1].to_i >= 7
                		model.start_operation("bomb groups",true)
                		puts "Using enhanced speed mode"
                	else
                		model.start_operation "bomb groups"
                	defs.each do |d|
                 		puts "exploding #{(itotal = d.instances.length)} instances of #{d.name}"
                		d.instances.each do |e|
                			e.explode
                		Sketchup.set_status_text "Collapseing Your Action 3D Model"
                	model.commit_operation
                	Sketchup.set_status_text("Your Model Has Been Collapsed And You Can Now View The Models Price")
                	UI.messagebox("Your Model Has Been Collapsed And You Can Now View The Models Price",MB_OK)
                unless file_loaded?("bomb.rb")
                # BEGIN CHANGES BY organizerEdit.rb
                	file_loaded("bomb.rb")
                	if $submenu!=nil
                		$submenu.add_item("Bomb All") { bomb_groups }
                # END CHANGES BY organizerEdit.rb
                bomb_groups
                  Sorry 😳 - I made a typo, try this... there was loose ) after entities !
                  Sketchup.active_model.active_entities.each{|e|e.explode if e.class==Sketchup::ComponentInstance}
                    simonstaton
                    wewt! thanks man that worked a dream. ive spent so long on this thanks 😃
