    Exploding Using Ruby Script
    9 Posts 3 Posters 2.0k Views 3 Watching
      simonstaton
      Basicly I want to explode all the components on the page using a ruby script. I have a
      component inside of a component and the component that is inside the
      main one has attributes so I do not want to explode it completly but
      only explode it once as if I was right clicking then selecting
      explode.
      So far I have made a toolbar that when you press selects everything on
      the page then next I want it to explode this is my code so far.
       toolbar = UI::Toolbar.new "Action 3D Toolbar"
       cmd = UI::Command.new("Explode All") {
       Sketchup.send_action(21101)
       cmd.small_icon = "3dtoolbar.png"
       cmd.large_icon = "3dtoolbar.png"
       cmd.tooltip = "Action 3D Toolbar"
       cmd.status_bar_text = "Testing the toolbars class"
       cmd.menu_text = "Test"
       toolbar = toolbar.add_item cmd
       toolbar.show
      now the only important part here is the Sketchup.send_action(21101)
      and 21101 is the syntax for select all. so all I need to do now is explode as if I am right clicking then selecting explode
      Now is there a syntax for explodeing as I have checked everywhere and
      cant find one maybe somtyhing like this
      Sketchup.send_action “explode:”
        simonstaton
        no ideas?
        • tbdT Offline
          tbd
          Sketchup.active_model.selection[0].explode
          you need to add some error testing to see if a component is selected
          http://plugins.ro
            simonstaton
            that still isnt exploding it selects it all. also what do you mean by error testing
              {Sketchup.send_action(21101)} ### scrap it... no need to 'select' anything
              Use this line put inside your {}
              Sketchup.active_model.active_entities).each{|e|e.explode if e.class==Sketchup;;ComponentInstance}
                simonstaton
                that just gave me this error
                C;/Documents and Settings/Administrator/Desktop/action3d/Plugins/Utilities/Toolbar.rb;5; syntax error
                                                           ^Error Loading File LoadToolbar.rb
                  simonstaton
                  I have just been playing around with the bomb.rb plugin however this does explode it but it explodes it completly and I only want it to explode once. This is the code that explodes all the components complely.
                  def bomb_groups
                  	model = Sketchup.active_model
                  	defs = model.definitions
                  	return nil if UI.messagebox("Are You Finished Building Your Climbing Frame This Will Colapse The Model", MB_YESNO) == 7
                  	if Sketchup.version[0,1].to_i >= 7
                  		model.start_operation("bomb groups",true)
                  		puts "Using enhanced speed mode"
                  	else
                  		model.start_operation "bomb groups"
                  	defs.each do |d|
                   		puts "exploding #{(itotal = d.instances.length)} instances of #{d.name}"
                  		d.instances.each do |e|
                  			e.explode
                  		Sketchup.set_status_text "Collapseing Your Action 3D Model"
                  	model.commit_operation
                  	Sketchup.set_status_text("Your Model Has Been Collapsed And You Can Now View The Models Price")
                  	UI.messagebox("Your Model Has Been Collapsed And You Can Now View The Models Price",MB_OK)
                  unless file_loaded?("bomb.rb")
                  # BEGIN CHANGES BY organizerEdit.rb
                  	file_loaded("bomb.rb")
                  	if $submenu!=nil
                  		$submenu.add_item("Bomb All") { bomb_groups }
                  # END CHANGES BY organizerEdit.rb
                  bomb_groups
                    Sorry 😳 - I made a typo, try this... there was loose ) after entities !
                    Sketchup.active_model.active_entities.each{|e|e.explode if e.class==Sketchup::ComponentInstance}
                      simonstaton
                      wewt! thanks man that worked a dream. ive spent so long on this thanks 😃
